#3101 |
Thanks for the fast answer! Will probably try this later on if i cant find a better placement for the PCB.
#3102 |
diyAudio Chief Moderator
Make sure you got spare semis, since this is beyond prototypes team tested territory, and that extension cabling is inductive in a sensitive place.
#3103 | |
#3104 |
You got to debug then. Maybe your CCS is in oscillation in your layout version, maybe some semi is out. Use the scope in main nodes, look for Vgs, Vbe, to be healthy etc. Give the reg a feed from first cap of raw supply to see if something changes.
#3105 |
Hello,
Did a little mistake when ordering part and bought dn2540 to92, so very little current flow... i have some dn2535 to220 on hand, can i use these? Vin is 280v... |
#3106 |
How many T092 did you bought? Where are you located? We can exchange some if you don't need them...
#3107 |
Hi Massimo, check your pm 's
#3108 |
Massimo your pm folder is full, i cannot reply to your msg...
#3109 |
I have running SSHV1, cascoded version. Between cold startup and warmed up run, I have 30V of difference. I am using 2SK170GR. Can I do something to make the output voltage not to drift with temperature? Thanks. |
#3110 |
Measure the real resistance in the trimmer and substitute for a low ppm fixed resistor.
| Regs - Shunt vs Series | richie00boy | Solid State | 42 | 14th March 2013 06:45 PM |
