#3091 |
aarghhh.... I don't have a suitable load resistor so can't test this Sunday. It'll have to wait until tomorrow.
Btw, PSUD2 tests it at 178V (which is too low for me, but still higher than I see when I hooked up the SSHV2) Screen shot 2012-07-22 at 4.55.40 PM.png |
#3092 |
diyAudio Chief Moderator
Did you have long non twisted wire between C3 and reg's input connector when you tested?
#3093 |
yes, maybe 40cm
#3094 |
Stick a capacitor across the input connector to decouple. Twist the wires if feasible. Also are your 100 Ohm gate resistors really near to the Supertex Mosfets gates and with short pin in your layout?
#3095 |
Unfortunately didn't help.
I noticed, though, that I am able to trim both the CCS and the voltage between -CCS: 95ma to 130ma -Voltage: 127V to 111V So I think the reg is working properly.... the gate resistors are within 1cm (or less) Last edited by studiostevus; 22nd July 2012 at 04:38 PM. |
#3096 |
It helped, because you couldn't trim anything before. Your low input voltage thing is you need a different transformer. This one sags a lot and/or your coils are too resistive for 30mA CCS not to drop much voltage.
#3097 |
You are probably right, but usually PSUD2 is quite spot-on:
I am using a transformer from a reputable source in Germany, multiple members have used it before without problems. The chokes are specified by the same source as 330Ohm. I have modeled this correctly in PSUD2. I did some further calculation, and think I could live with 170V input voltage (then I could have 150V output voltage which would work in my application). However I still don't understand this extreme sagging... |
#3098 |
Is the Tx internal resistance and chokes Rdc you feed to PSUD verified by measurement?
#3099 |
Salas, would there be any trouble using ~5-10cm wires from the Q3-spot on the PCB to mount the FET a little to the side?
#3100 |
Quite possibly, can't predict because it was never designed or tested like that. In any such a test I would move the gate resistor from PCB right at the pin (restore continuity at PCB also), hook scope on rail for oscillation stake out, and start at lower voltage if possible.
| Regs - Shunt vs Series | richie00boy | Solid State | 42 | 14th March 2013 06:45 PM |
