Simplistic Mosfet HV Shunt Regs - Page 309 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 3rd July 2012, 08:44 AM   #3081
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
As a plain inductor then. That's loading it no doubt. How much bias current your preamps run on 26 tubes? 6+6mA or 10+10mA?
Old 3rd July 2012, 09:28 AM   #3082
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
About 6mA per tube. I have my shunts set at 40mA, one per channel.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 3rd July 2012, 03:28 PM   #3083
albertli's Avatar
Salas, George,
OK 40mA for the reg.
Yes my power amp with 100k input and I'd like to try anything recommended for I want to pull the best from both opt and the reg. I'd firstly try using the primary as choke with Murdorf silver/gold 0.47 then go on with resistive load so to compare.
Will report asap.
Albert
Old 5th July 2012, 02:39 PM   #3084
albertli's Avatar
Salas & George,
Has done the compare with the RC & LC. I still like the LC, only 100H with 1660 10mA, it sounds a bit smoother to me. I need more higher B+ for the RC 22k load. RC measured a bit better with square wave up to 7K, 10k still acceptable and turned really ugly above 12k. LC is good up to 5.5k, sounds more open and not that congest/compress as 4.5:1. It also looks good down to 50 Hz. I'd like to try the LC route further with higher inductance choke, 200-300H. Will the reg handle the total of 600H, or I'll need another reg for the other channel ??
Albert
Old 5th July 2012, 05:49 PM   #3085
vgeorge's Avatar
100H is a bit low for the #26. I use the 1660pp which is more than 200H.
You can always put two chokes in series.
The reg can handle the total current for two channels, even if you use more induction, but two is better than one.
Old 6th July 2012, 06:41 AM   #3086
albertli's Avatar
Thanks George,
I have couple 0.22 FT-3 teflon on hand, would compare with the Murdorf silver gold. I already put the order for 4 156c chokes, and would try to follow Andy's route with 2 156c in series. Will let you know asap.
Albert
Old 22nd July 2012, 11:55 AM   #3087
Ok guys, help me in my thinking:
I have just designed, etched and soldered my first Salas HV shunt reg (SSHV2). I would like to use it in a line stage, which will be a ~12mA load @ 200V. Hence I use a 15K dummy load (200/0.012=16.6K).
My raw supply is as follows (dual mono):
Transformer -> EZ80 -> CLCLC (-> SSHV2)
On the 100K bleeder resistor I am using, the PSU gives 220V.
When I attach the SSHV2 with a 15K load, I observe the following:
- SSHV2 led goes on (that's a good sign!)
- Input voltage is 125V... that's less that without load, but so much??
- Output voltage is 125V
- Across R5 (T.P.) I measure 95mV (so 9.5mA CCS)
- Turning any of the pots does not change output voltage/current
Am I missing something? The transformer has 100mA windings so should not be sagging so much....
Old 22nd July 2012, 11:57 AM   #3088
I would have been pretty proud if it had worked...
The whole reg is mounted on a huge heatsink
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 22nd July 2012, 12:43 PM   #3089
merlin el mago's Avatar
DC input must be 20VDC higher than Vout target
CCS target must be 20mA more spare for proper regs power consumption to good output impedance spec so setup your CCS current accordingly 12mA target + 20mA shunt needs you must set your CCS to 32mA
Old 22nd July 2012, 12:50 PM   #3090
Salas's Avatar
Try load your raw supply for ~30mA first, no reg associated. Does it hold?
Regs - Shunt vs Series richie00boy Solid State 57 6th October 2016 06:49 PM
Copyright 1999-2017 diyAudio
