#3061 |
diyAudio Chief Moderator
Try again for the pic. Go advanced, manage attachments, browse, upload. See it in current attachments list first, then submit reply.
#3062 | |
P.S. ECC81 eating 60mA??? Is there solid state also there? |
#3063 |
#3064 |
#3065 |
I place the original 47k resistor between caps, but surprise only one volt drop.
From 325 to 324v to be exact. I don't know how to further down voltage here. And concerning the 60mA consumtion, I remember to measure something as 0.06A with my cheap multimeter. But again not very confident with anything, I am a beguinner here. Tubes are a pair of good sounding Brimar 6060 "T"yellow logo, I think these are audiophiles ECC81. Nothing more. |
#3066 |
OK. Its a typical CRC. Take out C13 C14 and C20. That is we will try RC input to tame down the high 320VAC transformer. Its capable of 425VDC on C input even with losses. Sure that your buffer needs 60mA and not 6mA? Two ECC81 sounds like 6mA to me if there is nothing extra eating power.
If 6mA, use R1 2.7K 10W, set reg for 0.3V on TP, 37K 5W dummy. If 60mA load, use R1 1K 20W, set reg for 0.8V on TP, 3K7 20W dummy. Use 1uF plastic 400V directly across reg input if you got long cable from rectification or some other small value. |
#3067 | |
Also is your Tx really 320VAC if you measure AC on its output? (be careful). If you talk DC after bridge by mistake then we have to keep C13 and use only 10W 2K7 or 1K R1. |
#3068 |
I am not very confident to be able powering on the unit again as stock. I failed once and do not wants to repair. So sorry, no further reading the consumtion.
Attached is schemantic, the tube section on Jolida tube tuner 402. Blue marker shows deleted components as no need for gain stage. Active components are only two tubes 12AT7. Then the power transformer, I unplug the secondary winding and read AC 230v. One queston more please, I have as spare three good PIO capacitors ASC brand, also called "oil can" values 10, 10 and 30uF. I think these ae wonderful for tube power supplies, may I substitute the litlle lytics 100uF that come in stock? Also I have spare double C choke 10H/160mA. Do is SSHV2 benefit from these further smoothing? |
#3069 |
Ja jaa, I miss again the attachment!
#3070 |
If you delete that section then there is no reference and blocking for the next section. Also that last parallel 12AT7 section can not normally draw 60mA when rightly put together. That would be KT88 class A territory. Its wrong what you do I am afraid. SSHV2 alone you can test on dummy load with the 6mA standard and the associated guide for ~320VDC CRC and load I had given above. It will like PIO and choke also. But you should keep R1 for proper drop whatever the final pre-filter. Since I see many aspects not well defined in what you try to put together, I suggest you seek local help from some tube expert fellow so to convert and test for a correct standalone buffer and to set the reg safely for it. HV needs caution. Also watch the insulation and input safety of cheap DMM when measuring HV especially in series. I don't recommend you proceed alone, there are many weak points in the plan already and the reg reacting with smoke is a bad sign.
| Regs - Shunt vs Series | richie00boy | Solid State | 42 | 14th March 2013 06:45 PM |
