Go Back   Home > Forums > Amplifiers > Power Supplies
Old 27th May 2012, 04:53 AM   #3051
albertli's Avatar
Originally Posted by Salas View Post
My mind went to the tiny trimmer wiper now. Maybe a resistor in trimmer's place after you check the set value?
The idea did go over my mind once, but I gave up the thought for the reason that both channels with this symptoms the same time. I checked the temperature on the 170 with a laser gun. It showed almost 40c at the flat surface. The R4 100k 2w is rather hot at 60c and kind of close to the 170. Don't know if the R4 reflects the heat to the 170 or..............other reasons. Is R4 supposed to be this hot.
Old 27th May 2012, 08:17 AM   #3052
triode_al's Avatar
Albert, is it a PCB or P2P SSLV1?
Very P2P.
Agree to this weirdness (I can't stand things I don't understand )
I changed the trimmer 500 ohms (NOS) to new Bourns 200 ohms multiturn but that was no solution; replacing the MJE350 gave the improvement (that went away a bit later again).
My high voltage supplies are in the lab supply just 16uF/L/6uF/4uF and in my RIAA preamp it is 4 uF/L/30uF. Could it be these race from 250V DC to zero faster than the reference capacitor bleeds down? (But then, I have now installed a zener over there, of which the reverse diode is very effective in protecting the MJE350 B-E junction.)
So I did touch the SK170 (experiment somewhat like Albertli did): immediately the voltage drifted a bit. It went down tens of mV (on the scope it drifted).
If thermal responsiveness of the 2SK170 is a cause, I can check it with a 2SK30, which is known precisely for that good point: no or little thermal drift. (I choose that jFET for my lab supply for that reason .. even though the 2SK170 has a lower noise).
The output behaviour itself is quite acceptable now, just I know that this type of noise is transmitted to an output quite quickly (standard anode loaded triodes have low PSRR), while 50 Hz hum goes rather undetected, these DC-shifts can be experienced more.
albert
DAC TDA1541 S1; MC30-Super --> two stage RIAA; SP-6 clone ; 300B PP: 6N7/ECC82, Metalimphy output.
Old 27th May 2012, 11:25 AM   #3053
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Albert & Albert:
So the pots are good.
40C on the K170 is high to be self produced in that bias it uses. It should be radiated from a nearby object. Either a more indifferent fet or some way to protect it from varying heat. A 5W R4. I have experience with 2SK30ATM, problem is in this app it should not have more than 0.6V VGS(OFF) so the under 1mA IDSS ones from a bag should be used. You may need higher Rvref to reach previous Vo. Its noise figure is low, but at very high impedance. We still give it ~100K here so it should be quiet. A low side IDSS BF245A is a good option too.
Old 27th May 2012, 03:11 PM   #3054
triode_al's Avatar
I've been looking lately at the 2SK246 too; this is very linear at low voltages (better at a lower Vds at low Id than both 2SK30 and 2SK170).
The other trick could be to hide the main jFET with a cascode. It makes the jFET more temperature stable and might have an improvement too of the input capacitance of the gate. [In fact, a cascode is what I used a tube for in my HV supply]. I would still call this simplistic, as the main error amp is the MJE350/powerFET.
I'll try this asap
Old 27th May 2012, 04:41 PM   #3055
triode_al's Avatar
Oops, of course a cascode won't work at 0,6 V Sorry for that, won't even try it...
Old 3rd June 2012, 08:45 PM   #3056
JOIMONF is offline JOIMONF  Spain
After very good results with SSLV1.0 to power a Tripath, I am trying to run now my first SSHV2, but after several attempts, still no success. I have burned some zeners, one KSA1381 and three DN2540 yet.
Now I have only one DN2554 healty and miss another one to continue amusing this way.
My cuestion, do is possible to place as Q1 or Q2, IRF9610 ?
Input voltage is 310v and output should be 225v/60mA.
Thanks in advanced.
Old 3rd June 2012, 08:52 PM   #3057
Salas's Avatar
Lower the input-output drop down to 20V-50V. Use CRC in your rectification for that. Try a capacitor directly across SSHV2's DC input for decoupling.
Old 3rd June 2012, 09:00 PM   #3058
merlin el mago's Avatar
Let's go Jordi
Old 3rd June 2012, 09:02 PM   #3059
Salas's Avatar
P.S. No, those DN are 400V depletion Mosfets, you can't sub them with 9610. Some info about your rectification stage and your load application could help assess.
Old 3rd June 2012, 09:56 PM   #3060
On pic attached I hope it appears the circuitery on rectification stage. Yellow marker are components deleated, and blue color marker is 4k7 resistor value I changed to raise up the voltage (now I see that's wrong) There is 320v on secondaries, then CRC 100uF/4k7/100uf after modification.
This powers a pair ECC81, on a buffer stage, eating 225v./60mA.
I placed a dummy load resistor: 13k7/8w.
And expect to fix 800mV. on TP but never got start the module.
Regs - Shunt vs Series richie00boy Solid State 42 14th March 2013 06:45 PM
Copyright ©1999-2013 diyAudio
