#3041 | |
So you need to immediately MJE 840 and 350. thanks
Group buy DAC-END R (ES9018) full assembled board update 21/5/2013 : https://docs.google.com/spreadsheet/...FE&hl=en#gid=0 |
#3042 |
Clueless
Just about to fire up, need a couple of caps though..
Is C1 value 330nF critical for the zobel? I have plenty of 220nF and 470nF. Cheers
Broke solderer with delusions of grandeur |
#3043 |
As I reported some instability some time back, I today set myself to some part changes.
I changed the pot, I changed the set resistor: replacing the MJE had success. With a new MJE350 it worked well, flat on 2 mV/cm. For a little time. because . . . when I changed the voltage (200 ohms multiturn potmeter; 2SK170GR/110K) then all at once the problem stated a bit again: now there is again a little bit of instability around 10 mV peakpeak. Is my conclusion right that the MJE350 cannot stand tweaking the voltage [even though it is a few volts to the turn)? I now have a 12V BE zener; maybe 4V1 is better (the max Vbe being 5 V)? I'm afraid I fried another MJE already. NOW - - I'm chicken.
DAC TDA1541 S1; MC30-Super --> two stage RIAA; SP-6 clone ; 300B PP: 6N7/ECC82, Metalimphy output.
#3044 |
Erratum.
While I was away for over half an hour it has settled again, though there is a very mild drift of +/- 2 mV, now it is stable in time. No jolts. The output voltage went up from 200V to 203 in the mean time, that is of probably the 2SK170 doing its own figuring out how to respond to the warming up of the earth. Like it is it can be used in a preamp again. (I tested with a lab supply 220V-240V, 750 ohms source resistor, that is a good setting to take the current limit out of the test.) albert
#3045 |
Salas,
I have both 170 replaced, but sorry to let you know they're still the same. It drifts very minor at start and I almost can tune to my desired voltage, then it drifts the way up to the supply voltage 217v. I even tried to tune it back down to 145v, then suddenly the voltage free fall to around 41.5v and stop. I also have the 2 zeners at 9610 replaced, but won't help. I took the 9610 out from the board and checked them with the new one. The readings seemed normal. Albert |
#3046 |
diyAudio Chief Moderator
Albert, is it a PCB or P2P SSLV1?
#3047 |
#3048 | |
#3049 | |
#3050 |
| Regs - Shunt vs Series | richie00boy | Solid State | 42 | 14th March 2013 06:45 PM |
