Simplistic Mosfet HV Shunt Regs
Old 11th May 2012, 06:05 PM   #3001
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by Salas View Post
-- But strap a 12V Zener from C2&R9 node to +Vo rail (cathode up) along upping the capacitance not to zap the JFET.
Salas, Good find.
That could very well be the cause, my raw capacitance in the LCLC is only 10+30 uF so it races down immediately with a current drain of 65 mA.
Would a diode work as well? Cathode to the plus, anode to C2&R9 node? That is how I would solve it. I must try it tomorrow.
albert
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
Old 11th May 2012, 06:45 PM   #3002
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
No, use Zener. Cathode to plus. Up C2 if you can also. But see with better raw filtering first.
Old 12th May 2012, 02:45 PM   #3003
triode_al's Avatar
I added the pre-regulator. (Fet with a 180k/4 uF filter; guarded with a reverse diode over the 180k). That is absolutely silent. Dead flat.
Still some reg-output flutter.
I think the reason is there is a loose connection in an amplification stage: the output jumps once in a while and the regulator voltage drops a little as response, just a little later.
Oh my. Having to revisit all solder joints ..
albert
Old 12th May 2012, 03:00 PM   #3004
Salas's Avatar
Could be, weird though. Some junction thermal cycle in the semis? But yes, first things first. Check the joints.
Old 12th May 2012, 04:58 PM   #3005
triode_al's Avatar
I will test with external 10k, 20 watt types (no output): one or two parallel.
Then I will detach the stages one by one (though I know it is not the input stage) but the problem starts at the second one (6SL7).
As regards semi's, a joint with different solder type might also be a problem. I have Sn-Ag 2% solder (from China, I bought it my self at a main distributor), but I found it is excellent for first soldering, once you rework it, it breaks apart (no flux left or so). This is just mine conjecture and I have not heard others talk about this strange phenomenon.
I am listening now to the RIAA stage: nice, lively. The 'noise' is far in the background and more or less disappears referenced to normal listening after half an hour. I also note the voltage goes up a few volts in this time period.
albert
Old 12th May 2012, 07:35 PM   #3006
Salas's Avatar
That's a normal Vo drift up due to Tc in the junctions but no sudden jumps should be considered normal. Is there any extra rail decoupler cap on the 2nd stage?
Old 13th May 2012, 10:18 AM   #3007
triode_al's Avatar
Yes, I have 2n7 (mica) rail decoupler caps on input board and I have 5 uF that is the point where all the power comes from.
  • Should I take out all caps? Or put a 4 ohms on this point?
  • Issue is that I saw that the noise spectum rises with a 20 kHz signal and no caps . .
A trace with 500 Hz out to show the regulation (a few days ago) just input stage. Regulation trace is on 2 mV/cm. 4 volts out pp. Not bad really!
So no 5 uF yet connected.
The the current situation (indeed with 5uF):
PU MC pre L101672456.jpg and non periodic it is: PU MC pre L101672758.jpg
It sags in a non-periodic timeline.
I took out tubes and it got better (that is: less frequent bumps). This is with only the first stage, one line is power out the other the preamp out, both 10 mV/cm. The noise comes from the regulator.
My board:
I am now replacing the jFET (went from BL to GR), and will take out the 5uF.
Old 13th May 2012, 01:34 PM   #3008
triode_al's Avatar
Originally Posted by triode_al View Post
Update: Replaced the jFET
Last evening I stopped the vinyl, these background subsonic ticks were nerve-breaking!
I relistened today - worse in fact.
As the pictures show I had it all right at first, but while I readjusted for a higher voltage out, the problems started to occur: I tried various LCLC combinations, this must have caused some harm somewhere.
Oh well, after days of tinkering I'll go more traditional. Then next week I will recheck the shunt PCB on the lab supply.
albert
Old 13th May 2012, 01:56 PM   #3009
Salas's Avatar
The caps on the load rails short the reg's zobel for AC. Either delete them or buffer them with series resistors to form RC. You got instability.
Old 13th May 2012, 06:50 PM   #3010
triode_al's Avatar
Salas,
I have 3,9 ohms and 1,2 uF. I thought this would be an adequate value. I understand the Zobel component values are very critical then. Probably it also depends on the shunt device transconductance (mine has a lower S - 3.9 versus 4.9 for the IRF840). [LIST][*]could I isolate the amp with an inductor, 200 ohms, 2 Henry, then 220 uF electrolytic and 5 uF MKP? [/LIST
I tested it, it works, but I saw the electrolytic introduces its own noise spectrum!
Thanks for the support.
albert
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
