Simplistic Mosfet HV Shunt Regs
Old 26th April 2012, 11:36 AM   #2951
AndrewT is online now AndrewT  Scotland
Originally Posted by crazyfrog View Post
Those Sense and Force connections are needed to get the regulator performing well.
No. they are used to minimise the effect of long resistive/reactive connections between the sensing circuit and the load. If the load is located at the Shunt mosFET and the sense traces were tapped into the same points then separate S & F would not be required. But, we can't build a practical load circuit where the load is at the FET leadouts.
Similarly if the load is directly connected across the reg output terminals, then the S would be connected to the F at the output terminals, as I suggested above for "easy" implementation.
regards Andrew T.
Old 26th April 2012, 04:04 PM   #2952
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Forgive my lack of knowledge but that four wires out looks complicated to me. Usually I just have to deal with "in, out and adjust"...
I want to use the SSHV2 with my 12B4 preamp (Salas version).
A bit more information would be welcome.
Thanks.
The subjective upgrade will not reach 100% potential if you will skip the 4 wire connection. The longer the cables the more the benefit to have by changing your now traditional power feed double wire run in an already made build. It will work in the classical way if the force and sense are closed right at the reg's output connections if rewiring is a hassle no problem, but do try to upgrade later. Recommended for SSHV2.
Caution: Don't operate the reg without sense and force closing circuit either remotely or locally. It may bring damage to the reg.
Old 27th April 2012, 03:15 AM   #2953
crazyfrog is offline crazyfrog  Canada
Got the picture in the meantime. It looks like a commercial power supply I saw with some kind of "probe system" inside. It was connected to a pair of twisted cables. But the current was much higher and the voltage much lower. The situation is different here. High voltage with low current seems less critical.
Old 29th April 2012, 05:16 PM   #2954
gianmaria is offline gianmaria  Italy
Default SSHV1 for 60 Volts / 50mA output
Dear Salas, All,
I built SSHV1 for 300v, I would kindly like to know if the same circuit may be adapted for 55-60 vout and 80-90vin with 50-60mA load and which value I may use.
I searched the threads (not all) but I didn't find it.
I found one in the SSLV1.1 but I would like to implement it with the SSHV1 circuit.
Which value should I modify on the SSHV1 official schematic that can be find here:
Thanks a lot in advance for your help!
Gianmaria
Old 29th April 2012, 07:10 PM   #2955
Salas's Avatar
You should make R4 15K 1W and R3 22K 2W.
Old 30th April 2012, 09:02 AM   #2956
Dear Salas,
Thanks a lot!
I will try in the next days and I'll let you know...
Gianmaria
Old 30th April 2012, 09:51 AM   #2957
@ 60mA & 35Vdrop, the CCS FET will need to dissipate 2W. It needs a sink.
If the output is shorted, the dissipation jumps to 5.4W. Will the FET survive a shorted output? and return to normal working when the accidental short is removed?
One of the really nice features of a CCS Shunt regulator is that it can be bomb proof. But high input voltage makes this more difficult to design for, not impossible.
regards Andrew T.
Old 3rd May 2012, 09:33 AM   #2958
Brouilly is offline Brouilly  United Kingdom
Brouilly's Avatar
Could someone please explain the point of R6 1R8, and how critical it is to get the correct value?
Cheers
Broke solderer with delusions of grandeur
Old 3rd May 2012, 10:13 AM   #2959
Brouilly's Avatar
Originally Posted by Salas View Post
Stixx is correct.
Also if there isn't any special Wattage need for R6, you can use 1/4W. C3 is a dead end for DC, so virtually no energy consumption on R6.
Together they form a Zobel terminal block that helps transient overshoot performance. See how it overshoots at IRF840's gate for current without the Zobel.
OK, so that is the reason for it. How about value? The smallest I have is 1R or 2R.
Old 3rd May 2012, 10:38 AM   #2960
Salas's Avatar
It is critical to phase margin.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
Copyright ©1999-2017 diyAudio
