#2941 |
#2942 |
Salas/others,
Due to space limitations I will have to design my own board for 2 SSHV2's. - Are there any layout recommendations? (components that should be as close as possible to one another, components that should be furthest apart?) Thanks! |
#2943 |
diyAudio Chief Moderator
The input CCS is critical for compactness primarily. In the GB PCB it works with 100 Ohm gate resistors which is generally not that common, people use >=1K to damp the depletion semis, alas if you need to, it cuts PSRR dB max spec in the highs.
#2944 |
Contributor
Hey Salas,
Whereabouts is the GB for the PCB please? Thanks, D |
#2945 |
At the GB forums.
#2946 |
Contributor
Well that was a dummy question on my part then.....
Thanks Salas. |
#2947 |
Forgive my lack of knowledge but that four wires out looks complicated to me. Usually I just have to deal with "in, out and adjust"...
I want to use the SSHV2 with my 12B4 preamp (Salas version). A bit more information would be welcome. Thanks. |
#2948 |
You have two pairs of wires that connect at the load.. Sense and Force (remote sensing).
So both S and F are going to your plus side while both SO and FO go to the ground side. You should also download the build guide at post no. 2704. |
#2949 |
Connect each S to the respective F at the regulator.
Now you have a two wire connection to your load. It's that easy if you want it to be that easy. |
#2950 |
I have. Those Sense and Force connections are needed to get the regulator performing well. Thanks.
| Regs - Shunt vs Series | richie00boy | Solid State | 42 | 14th March 2013 06:45 PM |
