Simplistic Mosfet HV Shunt Regs
Old 14th April 2012, 06:09 PM   #2931
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Yes I know but I forgot to shield the low level signal and it's an important thing because I remember when I make your Simplisitic NJFET RIAA.
Old 14th April 2012, 06:12 PM   #2932
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Just watch with the meter there is no remaining HV anywhere when you tweak.
Old 14th April 2012, 06:22 PM   #2933
Thank you Salas for kind advice, I finished few minutes ago grounding the signal cable, I will test & rapport.
Old 15th April 2012, 12:15 AM   #2934
nicoch58 is offline nicoch58  Europe
merlin, re do the solder joint on rca ,don't look so good, at last on pic.... ag without pb ?
Old 15th April 2012, 02:09 AM   #2935
bigpandahk is offline bigpandahk  Hong Kong
Originally Posted by Salas View Post
P.S. What kind of phono is yours big pandah? Can you remind?
My phono is Toccata MK II, A variation of the Arthur Loesch Preamp Design by Thorsten Loesch
Old 15th April 2012, 02:12 AM   #2936
Salas's Avatar
Yes, now I remember. Thanks.
Old 15th April 2012, 12:49 PM   #2937
hktcm is offline hktcm  Hong Kong
SSHV1 can give more than 100mA if you will lower its ref and leds resistor to go under 100V too.
Many thanks
Old 15th April 2012, 01:38 PM   #2938
Do check the dissipation requirements of the CCS mosFET and the regulating mosFET.
This is especially important the higher the input voltage to the Salas Style Regulator.
regards Andrew T.
Old 16th April 2012, 11:53 PM   #2939
Swarky is offline Swarky  Spain
Any thoughts on the best caps (soundwise) for C1 and C2. Do you think itīs worth spending the extra for say Auricaps ?
Old 17th April 2012, 05:27 PM   #2940
Salas's Avatar
A subjective area, depends on taste and synergy with the rest. Those caps can be influential as far as anecdotal feedback maintains in the course of this thread. I would just swap a couple of models already in my stash to determine if there can be picked up changing my system's tone, before allocating funds to that. Such caps you mention can easily demand more $ than building a couple of regs themselves.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 04:59 PM
