Simplistic Mosfet HV Shunt Regs
Old 10th April 2012, 05:21 PM   #2891
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Great balls of fire
R2 disappeared & R5 burned, possibly D5 & D6 damaged
Old 10th April 2012, 05:30 PM   #2892
R.I.P.
Have you worked out yet how the Salas Shunt Regulator low voltage versions work?
Prior to gaining that knowledge I consider it stupidity to gamble with 240Vdc in a circuit you don't understand.
regards Andrew T.
Old 10th April 2012, 05:38 PM   #2893
iko is offline iko  Canada
iko's Avatar
Don't be so harsh Andrew; the moment you make PCBs available you will have to expect that people have some expectation of solder, plug, and play.
However, Andrew is right in that you need to be very careful with these high voltages. Someone should post a little guide of how to first test these regulators once soldering is finished. Dummy resistor, current calculations, etc. This may have very well been done, but I don't know it because I haven't been reading so carefully the thread lately.
Old 10th April 2012, 05:40 PM   #2894
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
At least the board is black and doesn' t show bad!
If I was you now, I would take out ALL the semis and check them. For sure one of the dn2540 is off.
I think you have shorted something.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 10th April 2012, 05:41 PM   #2895
vgeorge's Avatar
Iko,
Salas have already made a PDF for that.
Old 10th April 2012, 06:01 PM   #2896
@ Iko as you said I expected plug & play but possible is my fault: irf840 not isolated well from heatsink, I do the SSHV p2p and going OK 240V 60mA. Salas posted a PDF for this new version SSHV2, I followed his instructions to make it.
@George, OK I will change all semis for a new set to go fast.
Old 10th April 2012, 06:20 PM   #2897
vgeorge's Avatar
If you use the same pcb, check and clean it.
Don' t go fast, take your time.
When I first did it p2p it worked fine, because I took my time. I burned one or two semis when I was trying different ones and I thought that I gained confidence.
Old 11th April 2012, 09:44 AM   #2898
Changed all semis, diodes & burned resistors.
Max. current reached 319mA I read 0,319V across TP, Vout with this current 281V but can low the voltage to 240V the voltage is fixed 281V
If I reduce the Vout with R4 trimmer (used for adjust current) I can reach 240V but the current must reduced to 275mA I read 0,275V across TP
Old 11th April 2012, 09:45 AM   #2899
R.I.P.
The regulator half is not regulating.
regards Andrew T.
Old 11th April 2012, 11:33 AM   #2900
vgeorge's Avatar
Did you measure the parts that you replaced?
What was burned?
Also, what Andrew said, current regulator seems to be working, voltage regulator not.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
