Go Back   Home > Forums > Amplifiers > Power Supplies
Old 9th April 2012, 02:50 PM   #2851
merlin el mago's Avatar
It's OK if I have continuity between IRF840 & heatsink? I use two mica pads & a nylon nut & screw what is no way to isolate?
Old 9th April 2012, 03:02 PM   #2852
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Its not OK to have continuity between 840's metal tab and sink.
Old 9th April 2012, 03:04 PM   #2853
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Use a dummy load around 5k, to be sure there is no other mistake and test.
Do not fire the reg until you isolate it from the sink. You have the full output voltage on the sink now, which is kind of dangerous - even lethal.
I use a sil pad and screw with washer and no problems so far.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 9th April 2012, 03:54 PM   #2854
Isolated
I use 4K75 as dummy load, Vout max 17VDC, TP 600mV = 60mA
I'm afraid IRF840 isn't working wich voltage have to measure VGS?
Old 9th April 2012, 04:20 PM   #2855
Salas's Avatar
Use 10k to be light and try turning the trimmers. Led should be on.
Old 9th April 2012, 04:27 PM   #2856
vgeorge's Avatar
Voltage between gate and source should be 3,5V to 5V.
Check also that you do not have long leads between last cap and reg.
Old 9th April 2012, 04:38 PM   #2857
With 10K dummy load (two 4k75 in series) fixed 17 Vout can go up or low using R11 1K trimmer
Old 9th April 2012, 04:47 PM   #2858
VGS 3.9V
4-5cm
Old 9th April 2012, 04:57 PM   #2859
vgeorge's Avatar
Then the 840 is OK.
Check the BE voltage of the SA1381. Should be around 0,6V.
Led is lit?
Old 9th April 2012, 05:05 PM   #2860
0,15V
Yes
Regs - Shunt vs Series richie00boy Solid State 42 14th March 2013 06:45 PM
Copyright ©1999-2013 diyAudio
