#2771 |
diyAudio Chief Moderator
All well then. What type is it? SSHV1? Post some picture with your (SRPP?) phono.
#2772 |
Variac test, to bring it up slowly. What are your target settings and what is your raw dc source?
#2773 | |
I've built the first revision of the Salas SSHV and made a PCB for it, it works just fine. Are you using a PCB already made? Or are you using point-to-point wiring? If FETs are blowing, sounds like the gate voltage is being exceeded; or a FET backwards? Do you have a zener across the drain to source? I had this issue when I first built it, and found that the Vds was exceeded during the charge up of the capacitor. Another thing is to make sure the load is adequate for the desired output current. Perhaps you know someone that could go through the board with you before powering up? Hope that helps...it can be frustrating to figure these things out! Gary |
#2774 |
Thanks Salas and Roger57 's prompt reply. My target setting is 300V 75mA and the raw DC is 400V CLC. I changed the 56ohm to 22ohm for higher current. Last night I tested my latest built, connected a 5.6k 20W resistor as load, the output voltage go up to about only 25V, after a few second, the 22ohm on fire and the 9610 gone.
Will built a simple CRC connect to variac for testing again. |
#2775 |
Your raw DC is high for the 9610 at such CCS before it settles especially if there is a charging peak in an underdamped CLC pre-filter. Also much heat will be developed with 75mA and 100V drop over the reg. Burn some before. As you are, delete R10, C1, damp the input with 100 Ohm series, stick a 47uf/450V input to ground, a 12V Zener from top of the 1uf Vref capacitor C2 to Vo rail with cathode up and have a go. I suppose you already use clamping zeners on gates before the 220R stoppers to sources on both Mosfets. If not, look at the link from post#1 for SSHV1 again. Your R3 should be 82K/5W with such Vin. If all fails maybe a SSHV2 on a PCB would be better for you, but we can't be sure of any possible other difficulties in your case.
#2776 |
Thanks Salas, The input voltage is 300V and output is 250V 75mA. Sorry for my mistake. I will check the wiring again and use the calculator for the resistors. I've GB the SSHV2 and it may be better for me to wait for the kit
#2777 |
Do those things above anyway only don't put the 82k.
#2778 |
#2779 |
I have a peculiar problem. On one channel of sshv2, i have no voltage drop across zener, LED is not lighting up, and i just replaced jfet. Ccs is set and working at 45mA, but i only have 100mV at output.
#2780 |
Was working OK before, yes? In that case measure the semis. BJTs should have 0.6V between b,e IRF840 ~4V g,s. Maybe one of those is shot.
| Regs - Shunt vs Series | richie00boy | Solid State | 42 | 14th March 2013 06:45 PM |
