Go Back   Home > Forums > Amplifiers > Power Supplies
Old 6th February 2012, 12:33 AM   #2721
Sorr is offline Sorr  Australia
Default LEDS
Having trouble finding LEDS 2Vf @ 5mA.
Any types recommended?
Old 6th February 2012, 12:44 AM   #2722
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by marcus1 View Post
Will the SSHSV2 design in the latest group buy be able to produce a negative supply voltage as above with some parts changes?
Possibly in p2p for one, not on the positive board, but I haven't looked into it because I prefer this scheme, which is anti ground loop also:
Old 6th February 2012, 12:47 AM   #2723
Salas's Avatar
Any generic green 3mm will serve you well. That question was for SSHV1 I assume.
Old 6th February 2012, 12:58 AM   #2724
buzzforb's Avatar
This is different rectifiction layout that allows use of dual standard SSHV2?
Old 6th February 2012, 01:03 AM   #2725
Salas's Avatar
With that one you can arrange into +/-V any positive only raw PSUs or regulators be it chip, discrete, low voltage, high voltage, whatever. NAIM NAP 250 bolt on original was like that when I serviced one.
Old 6th February 2012, 01:04 AM   #2726
buzzforb's Avatar
Cool.
Old 6th February 2012, 01:08 AM   #2727
Salas's Avatar
Can't be done with two independent transformers. Common primary, two secondaries, single transformer, two bridges.
Old 6th February 2012, 02:29 AM   #2728
Yes the SSHV1
Old 6th February 2012, 08:21 AM   #2729
massimo is offline massimo  Italy
Why?
Old 6th February 2012, 08:27 AM   #2730
euro21 is offline euro21  Hungary
Negative SSHV2 test.
Regs - Shunt vs Series richie00boy Solid State 42 14th March 2013 06:45 PM
Copyright ©1999-2013 diyAudio
