Simplistic Mosfet HV Shunt Regs
Old 30th January 2012, 06:49 PM   #2661
R.I.P.
The Gate draws no current if the FET is working properly.
In this case there should never be any DC voltage across the gate stopper.
The LED has you scratching your head. Measure the voltage across it.
regards Andrew T.
Old 30th January 2012, 07:04 PM   #2662
buzzforb is offline buzzforb  United States
buzzforb's Avatar
20mV. No Vdrop across R11 or r12. It seems to me that it is the Jfet.
Old 30th January 2012, 08:24 PM   #2663
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
You need Vbe first for the fet to tick.
Old 30th January 2012, 09:27 PM   #2664
buzzforb's Avatar
Replaced both bjt's. No change and no light from led. Layout is correct. Cathode of led i attached to tpop of 68k resistor. No voltage at output. Im dying here
Old 30th January 2012, 09:30 PM   #2665
Salas's Avatar
Did you change fet also?
Old 30th January 2012, 09:33 PM   #2666
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Just relax. Walk away and do something else while your trouble shooting braincells recharge
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 30th January 2012, 09:39 PM   #2667
Salas's Avatar
First HV thing to do and that being SSHV2 on own inverted PCB ain't the easiest job. Tell you what, if it ain't gonna badge on reasonable debugging, continue with the pre, run it on additional RC cell to nominal B+ and wait, we gonna put PCBs out reasonably soon 'cause the protos hit 100%. OTOH, Mike, have we got one spare proto for Buzz? I think all are out already? No?
Old 30th January 2012, 09:49 PM   #2668
buzzforb's Avatar
840 or 170? No output voltage would suggest a short after ccs, correct. If detach sense wires from main rails, i shoul dread full voltage, correct.
Old 30th January 2012, 09:51 PM   #2669
buzzforb's Avatar
How bout a cup of tea!
Old 30th January 2012, 09:54 PM   #2670
Salas's Avatar
840 or 170?
170
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
