Simplistic Mosfet HV Shunt Regs
Old 21st January 2012, 07:30 PM   #2571
dadedady is offline dadedady  Greece
Hi Salas.
Do you think that BF245A is les drifty than 2SK170 (for SSHV2).
Old 21st January 2012, 07:37 PM   #2572
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Yes, but try only the lowest IDSS one you got as it has the lowest pinch off also. If pinch off (Vgs OFF) isn't lower than (-) 0.6V then its not working optimally here.
Old 22nd January 2012, 02:04 AM   #2573
j45yip is offline j45yip  Singapore
Originally Posted by regal View Post
Nice I have a similar SSHV1 but with WE417A (close cousin to your tube.) Also in the proces of upgrading, but I am just going to make a new amp module, parafeed this time. Interested to know what OPT you are using as the SSHV's handling of inductance is always called into question?
...the SSHV1 is powering my 5687 wot pre with LL1660 as well and have no issues whatsoever...brought it to another level.
Old 23rd January 2012, 07:43 AM   #2574
king4joy is offline king4joy  Hong Kong
I need a SSHV2 board soon as GB is available.
My P-P SSHV2 is not in working order.....when connected to a 10K dummy load....the LED does not light up....
Old 23rd January 2012, 07:48 AM   #2575
Old 23rd January 2012, 07:52 AM   #2576
Sorry....I do not mean to post twice....I must have pressed the wrong button again twice....or something....sorry...
Old 23rd January 2012, 07:56 AM   #2577
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Have you checked your CCS first?
What is you voltage acroos R5?
Old 23rd January 2012, 08:03 AM   #2578
I disconnect in a hurry b/4 and sond, smoke, snd smell....
I have checked the p-p, they seem OK....but I will check again...
Old 23rd January 2012, 08:14 AM   #2579
I will need to wait till tomorrow before I can connect it again.....when I connect it again, what should I measure.....in order of important because it could be brief.....and I can only do it so quickly before smell comes....I guess.....
Old 23rd January 2012, 08:15 AM   #2580
vgeorge's Avatar
Smoke and smell, probably some semis are damaged.
Check them first before firing again.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
