Simplistic Mosfet HV Shunt Regs
Old 2nd January 2012, 06:03 PM   #2441
merlin el mago is offline merlin el mago
merlin el mago's Avatar
OK I will connect again with the old tx
Old 2nd January 2012, 06:05 PM   #2442
iko is offline iko  Canada
iko's Avatar
Originally Posted by merlin el mago View Post
voltage across R4 284V
Puresound MM if you want I can remove & connect a dummy load of 15K
voltage across R9 0V
voltage across R5 0V
Yes, you should fix it first with dummy resistor load.
0V across R5 is completely wrong. The shunt mosfet, Q3 isn't working at all. It needs something like 2V-4V across R5 (Vgs) to start working. Take Q2 out and measure with the diode tester between B-C and B-E. One way there should be no reading. The other way you should get a value that is close to each other (B-C and B-E).
Old 2nd January 2012, 06:23 PM   #2443
rclourenco is offline rclourenco  Portugal
Originally Posted by Salas View Post
No. You should float two positives from double secondaries and bridges.
Sorry, one more question, would this be good for around 85V DC?
Old 2nd January 2012, 06:27 PM   #2444
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
With lower Vref resistors. Make them half.
Old 2nd January 2012, 06:49 PM   #2445
Old tx 115 Vout max.
Old 2nd January 2012, 07:00 PM   #2446
iko's Avatar
Roughly, this is how the circuit should measure if it worked correctly.
Old 2nd January 2012, 07:04 PM   #2447
MJE350 B-C & B-E close reading.
Old 2nd January 2012, 07:07 PM   #2448
Vin?
Old 2nd January 2012, 07:13 PM   #2449
Salas's Avatar
How you had 260VDC out on 15k dummy yesterday? That was 17mA on the load only.
Old 2nd January 2012, 07:16 PM   #2450
Olx tx 115Vout is measured with Puresound MM instead the dummy load, it's the only change.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 04:59 PM
