Simplistic Mosfet HV Shunt Regs - Page 244 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 2nd January 2012, 03:56 PM   #2431
merlin el mago's Avatar
R4 240K
Vin 274V
Vout 119V max
V across R1 0.527-0.530 still few current 12mA
Old 2nd January 2012, 03:57 PM   #2432
iko is offline iko  Canada
iko's Avatar
What's the voltage across R4? Do you have a resistor load attached? If so, what value?
While you're at it, check the voltage across R9 and R5. Q2 might be out to pasture.
Old 2nd January 2012, 04:41 PM   #2433
voltage across R4 284V
Puresound MM if you want I can remove & connect a dummy load of 15K
voltage across R9 0V
voltage across R5 0V
Old 2nd January 2012, 04:43 PM   #2434
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by rclourenco View Post
Hi!
Is their any negative rail version of the SSHV2?
Thanks and regards,
No. You should float two positives from double secondaries and bridges.
Old 2nd January 2012, 04:45 PM   #2435
Salas's Avatar
Originally Posted by merlin el mago View Post
Voltage across R1 47R between 0.594V and 0.596 = 12mA 119Vout max.
Did you try with the old Tx yet?
Old 2nd January 2012, 04:49 PM   #2436
No, do you want that I try? now R4 240K I left or I come back to 120K?
Old 2nd January 2012, 04:53 PM   #2437
Salas's Avatar
Yes. 12mA is too low for 3 leds and 56R. Something smells funny. You had shown 260V on 15k dummy with the old Tx.
Old 2nd January 2012, 04:54 PM   #2438
Many thanks for your kindness.
Old 2nd January 2012, 04:57 PM   #2439
I left 240K for R4 or I change for 120K?
Old 2nd January 2012, 04:58 PM   #2440
Salas's Avatar
Indifferent, you will have range with 240k anyway. Just take it easy on the trimmer.
Regs - Shunt vs Series richie00boy Solid State 57 6th October 2016 05:49 PM
Copyright 1999-2017 diyAudio
