Simplistic Mosfet HV Shunt Regs
Old 30th December 2011, 06:50 PM   #2321
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by vgeorge View Post
Have you taken out and measure ALL the semiconductors and make sure they are OK? Do that before next try.
I changed all semis
Old 30th December 2011, 06:52 PM   #2322
Originally Posted by Salas View Post
Solder the Vin cables directly under Vin capacitor electrolytic.
I have to change all LEDs, once changed & Vin cables soldered directly to 150uF input cap, can I fire up?
Old 30th December 2011, 06:59 PM   #2323
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Then if everything is fresh, fets insulated from sink, there must be a short somewhere in the board. Clean and check. Maybe check continuity of output to ground. It shouldn' t be short.
Old 30th December 2011, 07:07 PM   #2324
No continuity at the output. Thanks for help George
Old 30th December 2011, 07:55 PM   #2325
Joshua_G is offline Joshua_G  Israel
Joshua_G's Avatar
The orientation of all SS devices should be double and triple checked. Also the value and Ohmic resistance of all resistors should be double and triple checked. Once both the above are correct and there are no short circuits on the PCB, the regulator should work fine. "Haste makes waste".
Old 30th December 2011, 08:21 PM   #2326
Done, I have to do something more or can I fire up?
Old 30th December 2011, 08:24 PM   #2327
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
If you also checked continuity you mentioned and no shorts on board's tracks give it another quick careful go.
Old 30th December 2011, 08:38 PM   #2328
This time only burned all LED's, now I will solder all LEDs fisically like p2p
Old 30th December 2011, 08:42 PM   #2329
Salas's Avatar
Abort. Have a wine, sleep, clean you head. HV is dangerous when frustrated. You will look very carefully into all details again soon.
Old 30th December 2011, 08:48 PM   #2330
iko is offline iko  Canada
iko's Avatar
Yes, best to take a break. Check everything with a fresh mind some other time. Check the pcb carefully for possible trace shorts via solder. Take all parts out and start anew. Also make sure you give it filtered DC from a trusted source. I suggest you use some zener diodes to protect the mosfets.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
