Simplistic Mosfet HV Shunt Regs
Old 30th December 2011, 12:04 PM   #2281
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by Salas View Post
Can the capacitors be too heavy kicking high spikes?
That's a real possibility so working with quanghao pcb
I left only 220uF psu & only 150uF reg: 47R + 220R + all LED's burned.
Changed 47R, 220R, all LED's, IRF9610 & SK170BL: LED's don't lit but when conect a 9V battery all LED's lit. After a moment powered the 220R gate resistor IRF9610 again burned also all LEDs burned.
Now all testing with a dummy load 15K 10W connected, always 0Vout.
Attached quanghao schematic & some pics of the assembled board
Old 30th December 2011, 12:32 PM   #2282
R.I.P.
The LEDs should be OK. They are in series with R3 which limits the current.
I am not so sure what happens to Q4 during start up?
Similarly Q1 takes a big hit during start up.
I cannot see why the LEDs fail if you have assembled the circuit correctly. Did Q1 fail first and take out R1 and then bypassed R3?
regards Andrew T.
Old 30th December 2011, 12:35 PM   #2283
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
So this sounds to me like LED's are in backwards. Seen that before in other builds, my builds etc.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 30th December 2011, 01:10 PM   #2284
I desoldered R1 56R & it's broken: 0 ohms. So I solder I new oneto see what's happen.
Old 30th December 2011, 01:56 PM   #2285
iko is offline iko  Canada
iko's Avatar
Every time a component goes it's highly likely it will take a few others with it. At this point you might want to test every transistor in the circuit to make sure they're ok.
Old 30th December 2011, 02:12 PM   #2286
Thanks Iko, I will follow your good advice.
Old 30th December 2011, 04:00 PM   #2287
R.I.P.
Merlin.
I think your have read your ohmmeter wrongly.
0.1 or 0.2 would indicate a short circuit.
0.L indicates overload. This is equivalent to open circuit, i.e. the screen cannot display a high enough value for the resistance it thinks it is measuring.
regards Andrew T.
Old 30th December 2011, 04:02 PM   #2288
Changed all semis + 56R adjust current resistor + 220R gate resistor IRF9610, LED's still don't lit, LED's tested with 9V battery and lit positive side connecting current adjust resistor and negative side connecting 100uF + 56K + 220R gate resistor IRF9610
Old 30th December 2011, 04:05 PM   #2289
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Is R3 56K 5W? Measure Ohm across it with the reg off.
Old 30th December 2011, 04:08 PM   #2290
Originally Posted by AndrewT View Post
Merlin.
Thanks AndrewT,
I understood correctly that the resistor measured have a high impendance at least morethan my DVM can read so the resistor isn't shorted it's open without any contact so that's the reason my DVM can read.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
