Simplistic Mosfet HV Shunt Regs
Old 29th December 2011, 05:12 PM   #2261
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
See if you have long cables to the regulators, put a capacitor across their inputs.
Old 29th December 2011, 05:20 PM   #2262
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by Salas View Post
Merlin see what's wrong feeding, grounding, or loading the regs. Something's fishy when two different ones give smoke.
I tested again the separate PSU and seems all OK
CLC, the last C is in the same quanghao reg 300uF
Old 29th December 2011, 05:23 PM   #2263
last C in the reg, BTW the cable between PSU & reg is 1 meter.
Old 29th December 2011, 05:25 PM   #2264
Salas's Avatar
Using so heavy last capacitor, why? Are your fins insulated between them? Maybe they touch?
Old 29th December 2011, 05:34 PM   #2265
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Ask again, did test with dummy first?
Old 29th December 2011, 05:41 PM   #2266
quanghao pcb caps are in parallel.
dvb-projekt connected without cap at the input reg.
Old 29th December 2011, 05:42 PM   #2267
No I did test with dummy load because burned, wich value in ohms & watts?
Old 29th December 2011, 05:49 PM   #2268
vgeorge's Avatar
You burned the dummy load? 15k 10W is a good allrounder.
Also I think you know you shouldn' t test the regs without a load.
Old 29th December 2011, 06:00 PM   #2269
NO I didn't burned the dummy load. Yes I know it's necessary to use a dummy load or the circuit, but the Puresound phono MM was going on perfectly well with other 240VAC tx, I only changed the tx so I supposed that all will go OK that's the reason I didn't used a dummy load but the reg was connected to the MM.
Old 29th December 2011, 06:09 PM   #2270
Dummy load ready for next regs.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
