Simplistic Mosfet HV Shunt Regs
Old 28th December 2011, 10:52 AM   #2231
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Default Old SMHV shunt regulator
I'm doing in a quanghao board the old SMHV, it uses irf9610 for CCS, MJE350 and irf8410.
Vin is 285VDC and I only get 0Vout, LED's are all ligthning so I think IRF9610 is OK but I don't know how I have to start to fix the issue.
Thanks for help
Old 28th December 2011, 11:05 AM   #2232
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Check vgs on both mosfets. Should be ~4V. Also check the Jfet.
Old 28th December 2011, 11:33 AM   #2233
IRF9610 9.3V
IRF840 3.5V
2SK170BL 0.59V
Old 28th December 2011, 11:57 AM   #2234
Salas's Avatar
Are you sure its 9.3V for 9610 between G & S (outer pins)?
Old 28th December 2011, 12:04 PM   #2235
Now 9.5V, see pic
Old 28th December 2011, 12:16 PM   #2236
Salas's Avatar
Looks much. But maybe because you got very large Vin-Vout right now. Can be bust. Check all your orientations, check if the system draws any current, change the easy ones, like MJE, FET, first.
Old 28th December 2011, 12:20 PM   #2237
OK i will start with sk170, mje350 and let you know. Thanks for help Nick.
N.B. SK170BL I have 6.60-6.78 range and 8.16-8.98 range, wich range will be better?
Old 28th December 2011, 12:25 PM   #2238
Salas's Avatar
Low range.
Old 28th December 2011, 01:46 PM   #2239
220R gate resistor IRF9610 fired
Old 28th December 2011, 01:52 PM   #2240
Salas's Avatar
You got a problem there. Change the Mosfet, its gate resistor, keep you rectification smoothing capacitor near input.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
