Go Back   Home > Forums > Amplifiers > Power Supplies
Old 26th December 2011, 05:42 AM   #2221
I try to use small sinks just try to get the board into the amp box...seems not quite possible especially if I may use 1 board per channel in the future...just hope that this board with remote sensing, I can get by with putting the board in the PSU box (with about 0.5 meter wires connecting) without too much negative...
Old 26th December 2011, 06:25 AM   #2222
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Seems you have to adjust your SSHV2 for two channels at 70mA then.
Maybe you could use the chassis as a sink for the 840, in order to save space inside?
Old 26th December 2011, 09:39 AM   #2223
What voltage is on the drain of these high voltage FETs?
The backplate of these FETs are able to be touched and prodded and wires dropped on etc.
Old 26th December 2011, 10:38 AM   #2224
vgeorge's Avatar
The first fet drain is at Vin.
I didn' t took temperature readings, but with 50mA and 200V there was no problem touching the sink for extended period.
Old 26th December 2011, 11:50 AM   #2225
With 200V on the drain and the drain being within the thickness of the electrical isolator of the heatsink, be very careful about where you put tools and fingers.
Old 27th December 2011, 02:27 AM   #2226
should we use two pieces of the isolator for high voltage??
Old 27th December 2011, 10:11 AM   #2227
The high voltage of itself is not a problem.
It's the accidental shorting of the copper backplate to anything at a different voltage that is the problem. Extra insulators cannot cure that.
The screwdriver tip will still span the gap from backplate to heatsink. The Finger can still touch the 200V.
Old 27th December 2011, 02:23 PM   #2228
luvdunhill's Avatar
Plastic devices are the best choice here.
Old 27th December 2011, 02:59 PM   #2229
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Luvdunhill, what are you refering to - caps or insulators?
Old 27th December 2011, 04:11 PM   #2230
luvdunhill's Avatar
Transistors.
Regs - Shunt vs Series richie00boy Solid State 42 14th March 2013 06:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
