Go Back   Home > Forums > Amplifiers > Power Supplies
Old 23rd December 2011, 08:15 AM   #2191
I will try and see how big heat sinks I need first...if heat sinks not too big, I can fit it in the amp box....but then I need to put the last cap in the amp box as well.....
Old 23rd December 2011, 08:25 AM   #2192
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
If you do not drop too much voltage a small sink for Q3 will do.
I think that a 0.1uf cap at the input will do also. Try and see.
Old 23rd December 2011, 08:35 AM   #2193
I think I just need to frop the minium for the board...say 20V...a 0.1uF 400V is not big....thankyou....you think it is not good to put the board in the PSU box??
Old 23rd December 2011, 08:36 AM   #2194
frop should read drop.....sorry
Old 23rd December 2011, 11:00 AM   #2195
vgeorge's Avatar
It' s always better to have the regulator close to the load.
Old 24th December 2011, 04:42 AM   #2196
What are the chances that Q4 and Q5 will need heat sink?? if they will not need heat sinks at all...I can put them closer...and make the board smaller...I plan to have Vout = 270-290V max.....
Old 24th December 2011, 09:02 AM   #2197
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
There are good chances they will not need mini sinks for under 300V if the box ain't much hot inside.
Old 24th December 2011, 10:33 AM   #2198
What are the dissipations of Q4 & Q5?
Use that information to estimate the Tj from the datasheet temperature de-rating.
Old 24th December 2011, 10:48 AM   #2199
Salas's Avatar
2mA @ ~150V each for 300V out.
Old 24th December 2011, 10:55 AM   #2200
King,
look at Salas posted pic.
2mA & 150Vce (or Vds) gives a dissipation of 300mW.
Find 300mW on the pic.
Draw a horizontal line at the 300mW height.
Where does the 300mW line cross the lower of the two plots? I'd guess about 115degC to 120degC.
The plot is telling you that at Ta ~115degC, the Tj = 150degC.
Now reduce Ta by 20C degrees to 95degC.
What is the new Tj? (answer, Tj=130degC)
Now reduce the Ta to what you estimate is the internal ambient temperature of the air around the regulator.
What is the estimated Tj?
If Tj < 100degC the device should survive long term.
If Tj < 70degC the device should never deteriorate in your lifetime.
Regs - Shunt vs Series richie00boy Solid State 42 14th March 2013 06:45 PM
Copyright ©1999-2013 diyAudio
