Simplistic Mosfet HV Shunt Regs - Page 212 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th December 2011, 08:18 AM   #2111
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Use what your load gets +20mA headroom. By your example, you can make double mono with 0.4V reading on TP or single with 0.6V reading on TP. Use dummy that gets as many mA as your load gets at nominal B+. If you got 20mA real load at 200V for instance, use 10K 10W test resistor load. Set R4 first.
Old 10th December 2011, 08:47 AM   #2112
Thankyou.....thankyou...
Old 10th December 2011, 09:51 AM   #2113
What would be a good sounding power supply for the SSHV2 in my tube line amp?? Does SSHV2 mind a choke input PSU?? or does it prefer others type...
Old 10th December 2011, 10:30 AM   #2114
Salas's Avatar
Whatever you will prefer in the total sound mix. It has no certain spec. Just needs a low ripple DC input 20V higher than the output you will set. LC, CLC, CRC were used with the previous version by many, most people seemed to prefer L instead of R in the pre-filter.
Old 10th December 2011, 12:05 PM   #2115
One more question before I get all the parts next week.....the Voltage in.....and out...mentioned; are they loaded or unloaded voltages??
Old 10th December 2011, 12:12 PM   #2116
Salas's Avatar
Loaded.
Old 10th December 2011, 12:12 PM   #2117
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Loaded.
Old 10th December 2011, 12:24 PM   #2118
Salas's Avatar
Talking about sync. LOL.
Old 10th December 2011, 01:06 PM   #2119
8:12pm vs 8:12pm.....no time smear at all....perfect....message taken...what a great forum...
Old 10th December 2011, 01:57 PM   #2120
regal is offline regal  United States
Can you define the low ripple roughly, as in the prototyping what were the incoming incoming ripple roughly (per sim like psud) ? I think I remember we discovered that SSHV1 did better with more pre-filtering than initially thought.
As far as the earlier post regarding using this reg with a CCS, I remember reading one of Olsen's presentations where there was a benefit to using a shunt reg before a CCS as far as isolating the music signal from the power supply. But remember you will lose 20V's headroom just inserting the reg, which may in many preamp designs be too much to allow the CCS to do its job. But most likely the 20V's can be gained back via loosening up the pre-filter in an existing design. But we probably need to nail down the max incoming ripple a bit (I imagine is depends on the load and shunt current.)
You mentioned some prefering CLC to CRC. One last question, does the output impedance of the prefiter matter at all?
Regs - Shunt vs Series richie00boy Solid State 57 6th October 2016 06:49 PM
Copyright 1999-2017 diyAudio
