Simplistic Mosfet HV Shunt Regs
Old 31st August 2011, 12:14 PM   #1951
Stixx is offline Stixx  Germany
Stixx's Avatar
Follow up on the SSHV I built for the C3G-SE amp...
It fired up with no problems (into dummy load at first, then into the circuit).
Rset is 33R, about 2.1V across it so around 64mA CCS, 30ish mA into the load.
Rset is socketed so will probably change to 39R to cut down on dissipation.
Sound is gorgeous... very open, dynamic and extremely detailed. I also have no
signs of harshness anymore... Rzobel is a 5R6 with spendy MKP caps, but it seems
to pay. Maybe the harshness was the standard Polyprop caps that I used before...
Dissipation into the cooler seems to be okay running the numbers and both Mosfets
connected to one cooler. Might have to connect it to the bottom plate once it goes
in the chassis... (see preview )
So was it an improvement...? Yes sir!
Otoons - Political Jokes :: Bush & Condoeeza
Old 31st August 2011, 12:27 PM   #1952
regal is offline regal  United States
Looks like a headamp? Have a similiar SSHV spud WE417 SE OPT (wonderful sound , a few minor bugs I'm working on), what OPT's are you using?
Last night I found that moving my OPT's 3 ft away from the power supply transformers dropped a bump at 60hz from -80db to -100dB
As far as Rzobel caps I also found a huge improvement upgrading these, went with K75's bypassed with the russian teflons (good bang for the buck.) I believe it is really the only cap in the signal path. If you look at pimms website, he shows a shunt supplied ccsload-parafeed here the only cap would be the parafeed cap.
Old 31st August 2011, 12:36 PM   #1953
quanghao is offline quanghao  Viet Nam
Simplistic Mosfet HV Shunt Regs Send a message via Yahoo to quanghao Simplistic Mosfet HV Shunt Regs
[QUOTE=Stixx;2692424]Follow up on the SSHV I built for the C3G-SE amp...
sounds great if you use 3 MKP 47uF capacitor before Salas HV shunt!
maximum just 150uF capacitor, without using additional parts CRC (UF-220R 220-220uF)
Old 31st August 2011, 12:38 PM   #1954
Originally Posted by sugarn View Post
Diode rectifier DHG10I1200PM.
http://docs-asia.electrocomponents.c...6b80af586e.pdf
For 250 volt bridge rectifier for tube pre-amp. power supply, anyone has ever tried it? is it good?
great and easy! SSHV a high-voltage power supply to upgrade Pre peak!
Old 31st August 2011, 12:39 PM   #1955
iko is offline iko  Canada
iko's Avatar
Could anyone please point me to the latest schematic?
Old 31st August 2011, 01:56 PM   #1956
I like this!
Old 31st August 2011, 04:40 PM   #1957
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Witch of the two you have changed to the K75.
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 31st August 2011, 04:41 PM   #1958
Stixx's Avatar
regal,
yes, it's a headamp. Seems as if I am only building headamps...(this one being Nr.7 )
OPT's are custom made from Reinhoefer (quite a well known winder around here) and are 7.5k : 300 ohm. They have taps for other combinations as well.
My amp (although still on the breadboard) is dead quiet despite the proximity of the OPT's to the psu... I am happy about that 'cause 3 ft makes for a large headamp.
Guess you are right on the caps but it plain looks better to have both caps the same kind... when I have some room left under my chassis I will try the russian teflons
though listening most of the day the tonal balance now leaves nothing to be desired.
Unless that urge to try someting starts itching again...
Old 31st August 2011, 04:44 PM   #1959
Stixx's Avatar
Which of the two you have changed to the K75.
Oliver, there is only one Zobel cap...
PS. Do you recognize your board?
Old 31st August 2011, 04:49 PM   #1960
Stixx's Avatar
The board I was using apparently was based on this schematic...
But to be sure we have to wait for the answer of Mr. N. Shuntregamouras...
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
