Simplistic Mosfet HV Shunt Regs
Old 2nd April 2011, 11:51 AM   #1721
kacernator is offline kacernator  Czech Republic
One more question. I am powering up the aikido preamp stage everything at once, the heaters and B+ at the same time. So the regulator feeds cold tubes for few seconds. Is this potentially dangerous to regulator in some way? I guess not, because I have this configuration running for almost half a year, but I am asking just to be sure.
Thank you.
Old 2nd April 2011, 02:00 PM   #1722
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
To the reg no, maybe it stresses your cathodes on the other hand. I had it with tube rectifier too, works nicely and comes up gradually.
Old 5th April 2011, 04:08 PM   #1723
Bengali is offline Bengali  United States
Hi Salas,
I've built your HV shunt with QH boards. sounds great.
in simple terms, what is the difference between your circuit
and this one, PS2 Solo?
Victory & Asymmetrical Amplifiers
this is for learning reasons, not to compare.
thanks
Old 5th April 2011, 04:53 PM   #1724
Salas's Avatar
That one is a reworked Maida series reg. Apples & oranges.
Old 5th April 2011, 10:59 PM   #1725
quanghao is offline quanghao  Viet Nam
Simplistic Mosfet HV Shunt Regs Send a message via Yahoo to quanghao Simplistic Mosfet HV Shunt Regs
Thank you.
no problem, if not have mane mA, you need for Pre!
does not matter if your Heatsinks is big enough for 840.
Old 7th April 2011, 06:29 AM   #1726
taniknight is offline taniknight  Australia
taniknight's Avatar
I'm collecting parts for a 300v SSHV as shown in post #967. The test suggests replacing Q2 MJE350 with a higher voltage part, namely the 400V MPSA94. This part is not available to me from my normal suppliers. Are there other suitable components for Q2 that I could try to source?
Thanks.
Old 7th April 2011, 06:45 AM   #1727
j45yip is offline j45yip  Singapore
my SSHV is working at 315vdc and mje350 at 295vdc for 6 months or so with no issues so far. i say give it a try.
Thanks.
Old 9th April 2011, 08:45 AM   #1728
manamanam is offline manamanam  Greece
I just powered the new regs and I see smoke coming from the current adj resistors. The resistors can handle 3 W. Any ideas what's wrong?
Old 9th April 2011, 08:55 AM   #1729
Found the problem. The voltage adj trimmer was set for too low Vout.
Old 9th April 2011, 09:59 AM   #1730
On duty..
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
