#1681 |
Hi Salas,
for my Tube-I-zator i have two possibilities to config my psu: ![]() Witch of the two would you prefer?
Reference TDA1541A DAC project PCB´s / Tube-I-zator PCB / SSHV-Shunt PCB
Stock status in my Blog |
#1682 |
I'm not salas, but the N.1 for sure!
#1683 |
diyAudio Chief Moderator
I would agree.
#1684 |
Thanks, that´s the way i had in my mind
#1685 |
Hello all.
I wish try the SSHV in a SE power amp. The +B is 330V at 86ma You could suggest me the inicial value for R1 for (86mA+25mA) 111mA? Some other advice? Thank you in advance, |
#1686 |
SE power amp may upset this regulator because of the output transformer's strong inductive load. It has been tried on smaller headphones amplifiers, can't say for this, its your test. 3 Leds of 1.9V drop each, R1=18R 2W, R3=67K 5W. 350VDC input. R4 120K make from 240K//240K 2W each. MJE350 may hold at 330V out, test stronger Vmax PNP if not.
#1687 |
Thank you for reply Salas.
I will try... Is better if use one reg for de output stage? is a 65mA load... Alberto. |
#1688 |
The input stage will benefit the most from a regulator. If it can not cooperate for the amp as a whole, run it lower current and use it for the input stage only. So it will not be left without a task if it can't serve for the power stage stably.
#1689 |
Hi Salas,
I'm planing a new 26 pre amp and would love to add 2 shunt regs for separated channels before the OPT. Please take a look at the attached and do advise if there is anything I have to pay more attention on. Thanks Albert |
#1690 |
Sorry, the attachment didn't go with it.
Basically I follow the new version with some changes. R1-56R, R3/56K and R5-100k. I go with CLC and split into 2 RC 180v to the regs. I'm aiming at 150v 9 mA. Albert |
| Regs - Shunt vs Series | richie00boy | Solid State | 42 | 14th March 2013 06:45 PM |
