Simplistic Mosfet HV Shunt Regs
Old 2nd March 2011, 08:22 PM   #1651
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hi Salas,
On my DAC output stage.
Simplistic Mosfet HV Shunt Regs-6n6p_rakk-gif
If I do Vin-Vout >= 15V there is hardly any extra shunt current at all. BUT I can already hear an improvement.
Only after Vin-Vout >= 90V there is about 55mA total current drawn. Resistor is 29R and voltage across it 1.63 or so.
I use dvb-projekt's boards.
Simplistic Mosfet HV Shunt Regs-ssssr-jpg
If you can see the speaker cone move...it's not hifi.
Old 2nd March 2011, 08:28 PM   #1652
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
So this is 14mA per channel load (5.6V on 390Rk). See to have 55-60mA indicated by the Vdrop on R1 ''Current Adj.'' divided by its value. If you are using double mono regs see to have 40mA on each R1.
Old 2nd March 2011, 08:30 PM   #1653
Each half of the 6n6p drew around 14,5mA before the SSSSR was installed. (Edit: Oops posted this before I saw your answer)
I just dawned on me that if the voltage goes down because of the regulator. The tube will draw less as well.....
Old 2nd March 2011, 08:33 PM   #1654
I'm using one at the moment. So I was aiming for (14,5+14,5)*2+25mA=85mA.
Old 2nd March 2011, 08:36 PM   #1655
Salas's Avatar
If you use 56R current Adj. it will set circa 40mA with average LEDS and Vgs. That is not enough if you supply two channels. The reg needs +25mA on top of that 30mA to the channels, for its own consumption purposes. 85mA is nice, drops its impedance a bit more, but your sinks look like are going to be taxed a bit. What is the value of your current Adj. resistor and what is the vdrop across it?
Old 2nd March 2011, 08:37 PM   #1656
current Adj. resistor and what is the vdrop across it? Common reg for both channels?
29R.(Two 56R in parallel) Voltage drop 1,63. And common reg for both channels yes. (But then the IRF840 and MJE350 become 90 degrees celcius) and there is major voltage drop.
Old 2nd March 2011, 08:49 PM   #1657
Salas's Avatar
That means 56mA CCS. Which is +26mA above your load demand. That is correct use. It also means around 6W dissipation for the IRF840 on that little sink. Maybe you have a mini sink to bolt on the MJE350? That would help it. Where and how much there is major voltage drop?
Old 2nd March 2011, 08:54 PM   #1658
What I was trying to say is that I only get that much current to be shunted if I dial the pot way down to 135V or so. (voltage drop)
And I did not solder the heat sinks in because I thought they would be too small. But that is all I had that fitted. I guess I'll have to go dual mono. And I might increase the b+ by going solid state rectifier and removing the CLCLCR with just some CR.
Old 2nd March 2011, 09:03 PM   #1659
Just did some quick measurements:
200v=36mA
180v=43,5mA
160v=50mA
Old 2nd March 2011, 09:08 PM   #1660
Salas's Avatar
That board was made by DVB for a certain DAC output stage, I think for under 200V B+ and less consumption. Its better you will use double mono so to have less heat when you go above 200V and the sinks to suffice. I recommend using a dummy load calculated for target load consumption at projected B+. Like 15K//15K (10W each) across 233V for 30mA, or just one for 15mA and be setting R1 for the proper +25mA margin by experiment. Then connecting to the real preamp.
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
