#1561 | |
diyAudio Chief Moderator
#1562 |
Ok, MJE350 will propably survive 300V Vout, will try. I will have 350V in and 300V out. Should I also change resistors R3 to 82k and R4 to 220k when Vin is 350V?
Thanks. |
#1563 |
Hi Salas,
on more question from me. Is it OK to use the 2N6520 even for voltages lower than 200V, or it is recommended to use the MJE350? |
#1564 | |
#1565 |
MJE350 has 300V Vceo spec no doubt. Not so high Vo to make other changes pressing, just use R3 68K 5W for more comfortable dissipation I would think.
#1566 |
Both work as it proved. 2N6520 is lower Cob and higher Ft. Below 200V it will dissipate comfortably too. You can try MJE also and decide on subjective grounds.
#1567 |
I use the 350 now, but I have a few 6520 and want to try.
Thanks |
#1568 | |
liftime , no mettter how others good parameters it has read the data more carefully
#1569 |
#1570 |
merlin , it's the question how you read the data
As I see it , the producer confirm during the 1000h of work , there will be no failure and max resistance change will be less then 0,5% after those 1000 h producer can't guaranty anything ![]() just for the compariton MBE0414 Beyschlag 50ppm - 33 cents/ pice after 1000h - delta R less 0,4% after 8000 h - delta R less 0,8% Those Caddocks are designed for aerospace , where there is a strict procedure what kind of elements you have to change after exact working time ( they calculate it ) I doubt you have some notice how many hours you use your audio system every day
| Regs - Shunt vs Series | richie00boy | Solid State | 42 | 14th March 2013 06:45 PM |
