Simplistic Mosfet HV Shunt Regs
Old 24th January 2011, 09:43 PM   #1551
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by Salas View Post
Yes. Vout. Must watch the permissible working voltage of the various resistors in HV applications too.
Old 25th January 2011, 02:19 AM   #1552
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
I try to get some Caddock Typ MS220/221
Click the image to open in full size. Click the image to open in full size.
Reference TDA1541A DAC project PCBīs / Tube-I-zator PCB
Stock status in my Blog
Old 25th January 2011, 08:05 AM   #1553
Excellent alternative: only one resistor TCR 50ppm tol. 1%, where do you buy?
Old 25th January 2011, 09:30 AM   #1554
kacernator is offline kacernator  Czech Republic
Default 300V operation
prior to my post of bad sounding Salas regulator, I had mistake in wiring, now it sounds very good. Anyway, my output target voltage is 300V. Is it ok to use schematics with MJE350 or should I go for schematics designed for more than 300V with 2N6520?
Thanks.
Old 25th January 2011, 10:12 AM   #1555
Salas uses 2N6520, Quanghao uses MJE350 for all Vout changing some resistors values on his pcb, so if you intended to use Salas schematic I will put 2N6520 & if you will use Quanghao pcb you can use MJE350.
MJE350
VCBO 300V
VCEO 300V
2N6520
VCBO 350V
VCEO 350V
Old 25th January 2011, 10:30 AM   #1556
So I should go with higher voltage version then. I cant buy 2N6520 in my country, but they do have BF493S (also 350V), so I hope it will work well as substitute.
Old 25th January 2011, 10:32 AM   #1557
Thatīs the problem. Nobody has them in stock. I try to get a quote from Caddock directly.
Old 25th January 2011, 11:21 AM   #1558
If possible count in me for 3 or 4 resistors?
I will ask a quote for Vishays, do you want to know the price?
Old 25th January 2011, 11:33 AM   #1559
Mouser have on stock 2N6520
2N6520TA Fairchild Semiconductor Bipolar Small Signal
Old 25th January 2011, 12:38 PM   #1560
pedefede is offline pedefede  Denmark
Default heat on Q3
finished the positive part of my dual 300V supply for Exstata. Its P2p.
The heatsinks are a bit small (the ones for exstata's PSU), so the tempereture on the heatsinks stabilized after 15 minutes.
For irf9610 to 50 C, and for irf840 to 80C
(A bit high i guess. Adding bigger heatsinks is a problem in my chassis design, so i will add a fan. For test i just put up a 12'' PC-fan, and the tempereture fell to only 40 C
I also measured the V-out during warmup, and there was quite a nice linear correlation between V-out and tempereture of (the heatsink of) irf840. V-out raised roughly 0,5V per degree C. Is that normal??
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
