Simplistic Mosfet HV Shunt Regs - Page 155 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 24th January 2011, 08:40 PM   #1541
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by merlin el mago View Post
I found 120K 2W 50ppm metal film but I suspect is inductive
WELWYN|MFP2-120K JI|RESISTOR, 2W 5% 120K | Farnell España
Don't know if there will be anything much to gain if non inductive, but low ppm is good to have since its a reference.
Old 24th January 2011, 08:48 PM   #1542
dodo is offline dodo  Poland
Originally Posted by Salas View Post
260-265V will suffice as minimum DC input to the 250V reg. 35mA will be enough for 16mA max load consumption. Make it 40mA if you can, its a bit better. CLC pre filtering and a good C2 or bypass, replacing the trimmer with a low ppm resistor after finding the value, a good C3 or bypass, a low ppm non inductive 120K Rref, short cabling to the load, that is about it.
I have used 2 x 242k Beyschlag PROFFESIONAL MBE0414 1W 50ppm with good results
But you have to buy a lot of them to find the same final rev after triming
Old 24th January 2011, 09:05 PM   #1543
Salas's Avatar
Non inductive is welcome, low ppm is first priority IF decided to go best resistor parts. Still it works adequately with common parts. In what application you used the SSHV? Had good results?
Old 24th January 2011, 10:24 PM   #1544
merlin el mago's Avatar
Other solution searching non inductive is Caddock MK132 0.75W in parallel 210K//287K = 1.5W 121K267, will be enough power?
Old 24th January 2011, 10:29 PM   #1545
Salas's Avatar
Up to 250V the ref resitor(s) will dissipate 0.5W. I consider 3x choice as wise always. So 1.5W will be OK up to 250V and 2W for 300V for example.
Old 24th January 2011, 10:33 PM   #1546
Are Vout of course?
For 2W Caddock MK132 4 resistors in parallel: 1 499K + 3 475K = 120K1952333 3W 50ppm
3 resistors in parallel 2W25 50ppm: 383K // 365K // 348K = 121K5915561
Old 24th January 2011, 10:36 PM   #1547
Salas's Avatar
Yes. Vout. Must watch the permissible working voltage of the various resistors in HV applications too.
Old 24th January 2011, 10:40 PM   #1548
Caddock MK132 are 400V/Max.
Old 24th January 2011, 10:41 PM   #1549
350V
Old 24th January 2011, 10:42 PM   #1550
500V
Regs - Shunt vs Series richie00boy Solid State 57 6th October 2016 06:49 PM
Copyright ©1999-2017 diyAudio
