Simplistic Mosfet HV Shunt Regs
Old 21st January 2011, 07:31 PM   #1531
nemo1968 is offline nemo1968  Croatia
Always recycling.
Old 21st January 2011, 08:09 PM   #1532
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by Salas View Post
Sure. Simply remember to allow 20-25mA spare in the reg after subtracting your max load draw from the total CCS setting.
Old 24th January 2011, 01:03 AM   #1533
Jean-Charles is offline Jean-Charles  Canada
Default HV settings for best performance.
Hi Salas.
I am sure this question has been answered many times before, but if I may: I want an output of 250V at a maximum of 16 m.a.. What would be the minimum voltage to input on the regulator to obtain optimun performances?
Would 35 m.a. be enough in the current department.
I read that bypassing C2 with a 100nf capacitor makes an interesting upgrade. Is there anything else we could do?
Thank you.
Old 24th January 2011, 01:16 AM   #1534
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
260-265V will suffice as minimum DC input to the 250V reg. 35mA will be enough for 16mA max load consumption. Make it 40mA if you can, its a bit better. CLC pre filtering and a good C2 or bypass, replacing the trimmer with a low ppm resistor after finding the value, a good C3 or bypass, a low ppm non inductive 120K Rref, short cabling to the load, that is about it.
Old 24th January 2011, 02:00 PM   #1535
The 120K Rref must be 2W or can be 1W or less, I'm asking this info due to the fact it's very difficult to get 2W in only one resistor with low ppm....
Old 24th January 2011, 02:58 PM   #1536
Salas's Avatar
2W or more. Many Volt across create dissipation. You can use 2x 220k-270k 1W in parallel. Arrange them in reverse direction between them. Like their color stripes or numbers & logo will look the opposite direction.
Old 24th January 2011, 05:53 PM   #1537
120K Vishay S106D 2W
http://www.texascomponents.com/pdf/vrths.pdf
Old 24th January 2011, 06:20 PM   #1538
Salas's Avatar
Dale RN70 in parallel wouldn't be bad also.
Old 24th January 2011, 06:56 PM   #1539
dodo is offline dodo  Poland
rather yes
200k-300k standard metal film (also RN Vishay) are quite inductive ( more the 10uH)
reverse parallel config will somehow reduce it but how much ??
best metal film tempoco for 2W resistors I have found 50ppm
MP 930 Caddock came to mine mind (noninductive -50ppm - but working voltage is a limit in HVSS
Old 24th January 2011, 07:06 PM   #1540
I found 120K 2W 50ppm metal film but I suspect is inductive
WELWYN|MFP2-120K JI|RESISTOR, 2W 5% 120K | Farnell Espaņa
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 03:59 PM
