#1261 | |
diyAudio Chief Moderator
#1262 | |
I don't think so. This isn't a power stage but I'm driving a line transformer and it seems to sound best in this set up around 30mA. Vp is much lower than some have used. If I remember it right, Larry Moore recommended running the 10Y at 425Vp-k/35mA ! !
(The only thing purpose built for the 10Y's at this point are the heater supply boards from Rod Coleman which I'd highly recommend. I was running LT108- based current regs before this and am really surprised that you can net such an impressive qualitative improvement from there to here.) I've noticed that if I set up the Simplistic regs and then shut down, when I fire everything up again the regs just sit there with only the CCS Vref voltage difference below the B+ at the output. I have to play with the trimmers again to get them to move. My first thought is that maybe the regulator doesn't like working straight into the reactance of the OT. I'll try a cap across the output to see if that changes it. Sound ? It's very good but the shift in the tube's op point is too much to be able to make a flat A-B comparison. Fine detail is everywhere - both structural and tonal - yet no sense of dryness or analytic sound. This is all just impressions but it's my guess if I get them running a little more predictably that they'll be excellent. |
#1263 |
Hearin Space, are you using a separate regulator per channel? If not the ICCS set to 60 mA, is not enough.
#1264 |
Yes, one per.
#1265 |
It better has some ESR. It will surely bring the zero phase cross much lower and maybe like the OT a bit more.
P.S. Go ahead and modify to the newer recommended reg. No point in matching the old. The new one is better in sonics also. |
#1266 |
It is as you say master. The left channel decided the low esr cap was just the ticket to freedom and is now gone on holiday. B+ on that side is now a steady and non-negotiable 74.5VDC.
The strangest part of it is that it sounds very nice. I think I've found a new op point for 10Y line stage tubes. ![]() Now to figure out what exactly blew on that board . The heat sink was stone cold . . . . . |
#1267 |
The MPSA?
#1268 |
I'll try that one first.
Which version ? The one with 2SK170 and MJE350? |
#1269 |
Yep.
#1270 |
OK. I'll build the new version as soon as I can get the 2SK
It wasn't the mpsa . . . Any reason you can think of why a two LM336-5 reference diodes (for a 10V ref) in place of the 3 LEDs wouldn't be a good idea? It's what I had on hand and seemed to be a simple choice. I'll pull the rest of the transistors and see how they are. I'm quickly learning why a roomy layout is a good idea for an experimental board especially when it comes to using small sand parts. |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Regs - Shunt vs Series | richie00boy | Solid State | 4 | 27th November 2003 07:09 PM |
| Page generated in 0.14473 seconds (74.88% PHP - 25.12% MySQL) with 11 queries |
