Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th December 2008, 01:38 PM   #1
chatziva's Avatar
Default What Power Supply for 12AX7 Preamp ?
Hi there,
I am very new to the world of valves but I want to give a valve preamp a go to sweeten the sound of my 100w gainclone.
I'd like to give this 12AX7 preamp a go but I have the feeling that its switching power supply with PMW chip is not a good quality solution (I might be wrong)
So, I was thinking something the lines of a shunt regulator or something.
Can someone propose a good quality, not too expensive PSU for this 12AX7 preamp?
It seems it needs +260V and +12V but don't know at how much current.
"I don't remember fighting Godzilla, but that's probably what I would've done"
Old 13th December 2008, 04:35 PM   #2
Brett's Avatar
Default Re: What Power Supply for 12AX7 Preamp ?
If you want to add a tube pre to a gsinclone, then consider something else than that design. A simple 6SN7, ECC99, 6H30, 6H6N anode loaded will give a better result than two 12AX7 stages with a ton of gNFB. As chipamps typically have a lot of gain, adding more will only mean you will throw it away in the volume control.
As for power supply for any tube amp, go to duncanamps.com, download PSUD2 and put in some values for Hammond transformers. If you want to do a regulator, search for Maida. Each stage of the 12AX7 design will draw about 1mA, so about 4 total and the heaters about 175mA/bottle in 12.6V config.
Old 14th December 2008, 01:48 PM   #3
chatziva's Avatar
Default Re: Re: What Power Supply for 12AX7 Preamp ?
I totally agree with you. But, as I said I am very new to the tube world... so I need to start from somewhere.
I think what you are saying is to use valves for a buffer stage, with unity gain right? Can you propose a design?
Thanks again
Old 22nd December 2008, 04:40 PM   #4
Gordy is offline Gordy  United Kingdom
Please note that a valve based preamplifier will not automatically add 'sweetness'. It's not as simple as that, despite what the audio-fools may write in their expensive magazines.
There seems to be little merit in the 12ax7 preamplifier found in the provided link. The 12ax7 has far more gain than you can use and they apply feedback to reduce it, then provide a complex power supply, and then a volume control at the output (i.e. a variable output impedance). Best to leave it on the page.
I suggest you first try a passive potentiometer in front of your amplifier. If you find that you need gain then look to the Aikido kit from Tubecad, which comes fully documented with a suitable power supply.
Old 23rd December 2008, 05:41 PM   #5
chatziva's Avatar
Good points about the 12AX7 preamp. Thanks for mentioning the Aikido designs, they are quite nice.
In terms of power supply I think I now have some choice, like the Aikido kits or Salas's HV shunt regulator.
In terms of the preamp stage itself I think I am better off with AlexW88's topology with 6922 or 12AU7 - Aikido's kit are slightly limiting the choice of tubes
preamp supply w/ 48v power impsick Power Supplies 16 27th April 2007 11:36 PM
Need Help for Power Supply for gg Preamp vangogh-hk Tubes / Valves 7 8th December 2005 02:00 PM
P88 preamp power supply Scribble Solid State 2 23rd January 2005 08:50 AM
12ax7 preamp,need help. digi01 Tubes / Valves 13 12th April 2004 07:00 AM
Boz Preamp Power Supply beppe Pass Labs 0 5th March 2002 08:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
