install PS in same case as amp
Old 13th December 2008, 04:07 AM   #1
curiousburke is offline curiousburke  United States
Default install PS in same case as amp
hello all,
I'm sorry if this has been discussed before, but I couldn't seem to come up with the right search terms to narrow the field.
I have recently acquired a Charlize amp and a case to put it in. I plane to use some sore of wallwart like thing to power it. Would there be any problem with gutting a wallwart and installing it in the case with the Charlize amp? I would then put a switch on the outside of the case to turn the power to the wallwart off.
Thanks for any advice,
Mark
Old 15th December 2008, 09:51 PM   #2
dtproff is offline dtproff  United States
Mark;
It really depends. Stick it in the case and see if you get noise out of the amp. Try and separate the PSU from the amp as much as possible. Use twisted pair wiring where possible and keep excess wire lengths to a minimum.
Listen to the amp then move it outside the enclosure and repeat the test.
Tony
Old 15th December 2008, 10:12 PM   #3
thanks Tony, good idea. I should have thought of just trying it, he says with his head down.
-m
Old 16th December 2008, 02:25 PM   #4
You know... The people in this forum have humbled me on more than one occasion. And I REALLY hate it when that happens!
Have a happy Holliday.
Tony
install PS in same case as ampHide this!Advertise here!
how do I install an LED jdbrocious Parts 7 1st March 2008 12:18 PM
New Sub And Amp Install Staticjeep Car Audio 0 2nd June 2006 07:21 PM
new install maxiboy Car Audio 6 26th June 2005 11:06 PM
Amp install Help PlEaSe. ebwilliams Car Audio 5 8th September 2004 04:28 AM
How do i install a cap? mcyates Multi-Way 7 21st February 2003 09:20 PM
