Dose a Capacitor have to be pre charged every time?
I am putting in a system on a boat where the DC is disconnected on the pannel when not in use. The stereo may sit idle for a month at a time. So if I precharge the capicator and put it in the system, won't I have to precharge it before every use if the power is disconcected between uses?
I did not know there were soft start capicators out there when I bought mine, otherwise I would have bought that.
thanks
AX tech editor
Joined 2002
thanks
Assuming you talk about the power supply reservoir capacitor, why would you need to precharge it at all?
What's a soft-start capacitor?
Jan Didden
soft start capacitors
A large capacitor draws a large amount of power and will arc or cause other damage with the large inrush of current.
A soft start capacitor has a series of resistors and a relay configured so that the power to the capacitor is not connected by the relay until a certain voltage has been achieved.
It must be a huge capacitor that you're using. Say if you're using a 1Farad cap, and off resistance of 1 million ohms, then your looking at a tau of 11.6 days to drop to 1/3 of the battery voltage.
So if it's sitting disconnected for a month it will be pretty much discharged. You could use a soft start circuit. Although I've never made one, i imagine putting a resistor between the battery and capacitor and having a relay bypass the resistor when the capacitor is charged would work.
Try searching for a slow start circuit.
Here's a circuit I designed for your soft-start:
This will take care of your inrush current. The comparator (LM339) turns on the relay after the capacitor has charged up to the battery voltage, minus a 0.6V diode drop.
The circuit will stay latched (on) until you disconnect the battery and drain the 1F cap.
You can use an Op-Amp in place of the LM339 if you prefer. You can also use a 10 ohm, 10W resistor in place of the light bulb.
