I bought a Keithley 182, it's a 6.5 digit voltmeter that is not working properly.
Display, OK (dot matrix), but no reading is triggered. No errors indicated on power-up test. I have not found the problem, but may have found the source of the problem......a very HOT power transformer. In fact there are two xformers, both are hot, but one is real hot.....as in, I cannot touch it for more than 1/2 second. What can cause a HOT transformer ? What would I check or measure ? Additional info: - No schematic (typical for Keithley) - The fuse is a 3/8 amp 250v slo-blow...it does not "blow". - The line voltage switch is in the correct 120v position (switch working, I checked). - Voltage checks: "Should be"........"But measures as" +40v..................+35v -40v..................-35v +15v..................+0.16v -15v..................-8v +5v....................+2.4v http://www.keithley.com/support/data?asset=793 ![]() =RR= |
#2 | |
Could be in the +15V voltage regulator part itself or in the circuits which are powered from it. I`d first try to disconnect the loads from the +/-15V power-supply board. When the DC supply voltages then measure about right (and with reasonable low ripple voltage) the fault is somewhere after the regulator. In this case it`s probably getting difficult to repair the thing without service manual. A fault in the power supply itself would be easier to find and fix.
Christoph STEAL the BEST - INVENT the REST |
#3 |
YES....I temporarily cut the traces from the +15 and -15v from psu.... to the analog circuits.
Power supply is working now that it is disconnected. There must be a problem downwind of those cut traces. Any tricks to finding a short in a network that powers about 15 opamps ? (My continuity tester does not beep if I bridge the analog's +15v power traces "to ground", or "to each other". (please don't tell me I need a 6.5 digit voltmeter, perhaps like a Keithley 182 There are 5 dipped tantalum caps, but no parts show any abuse. But one of them beeps with my meter, when bridged. |
#4 | |
Replaced it with a new tantalum cap. (10uf/50v) Reconnected PSU to analog circuits....now the voltages are good. The meter now works !!!! (paid $60 unworking "as-is"...they go for about $600-1000 used/working.) We'll see if the bad cap is an aberration, or a symptom of a problem somewhere else. Thanks for your tips cocolino ! =RR= |
#5 | ||
| Volume Surges Fender "The Twin" - transformer going? | jl_lensman | Tubes / Valves | 11 | 7th March 2012 06:06 AM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| "rule of thumb" used to determine xxVA for a power supply's transformer? | CopyofAudiófilo | Chip Amps | 11 | 22nd July 2008 12:01 PM |
| Building a high quality gainclone toroid coupling transformer with "tubeness" winding | ionomolo | Chip Amps | 16 | 13th February 2008 01:20 PM |
| Wanted: Hammond 125E or other "universal" output transformer | Spasticteapot | Swap Meet | 2 | 13th July 2007 10:29 PM |
| Page generated in 0.09819 seconds (76.45% PHP - 23.55% MySQL) with 10 queries |
