Because I have a slightly "larger" transformer (voltage wise) than that need for an application, I'm going to use a 1-2 Watt resistor (aka "power resistor") to drop about 7VDC. It will be located in/near the PSU rectifier, but before a typical 3-pin regulator.
The value of the power resistor will be ~160 ohm. Is it "best" to place this power resistor after the smoothing caps (aka main rectifier caps), or between diode bridge and the smoothing caps? A possible reason why "between" may be better is discussed in this topically unrelated thread on the PFM forum. (Note the position of R1 in the diagram). Thx for any feedback you can provide! |
#2 |
Hi
No doubt about it... the best performance is between rectifier and smoothing caps. Forms lowpass fuction with largest C. Also greatly reduces peak charging and minimizes cap esr requirements.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#3 |
Did it Himself
It has to go after the caps as that's the only way you can guarantee the voltage fed to the reg won't creep up to the full unwanted amount over times of light loading.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 | ||
... or can I?FYI: I'm probab. only going to use ONE smooting cap (~2000 uF). I could place a small R, say 1 ohm, between diodes and C. And, then, the 160 ohm power R after C (before reg.). |
#5 |
I agree with richie00boy. You need a small bypass cap on the output side of the resistor, across the regulator input.
#6 |
One Vbe multiplier transistor
would give a more constant voltage drop. Actually it will work like a zener. 10 x Vbe is ~ 6.5 volt I guess the current drawn is like 45 mA. (7V/160ohm) One TO-126 transistor could do the job.
lineup |
#7 |
If the system is lightly loaded then the 3 terminal regulator should be able to handle the higher voltage and low current. I'll go with "infinia" on this one and put the resistor between the rectifier and the big caps.
Kevin |
#8 |
Why not a pair of CL60 thermistors between the rectifiers and caps (one on pos rail and one on neg rail) ? It will drop 5v - 6v each rail and it serves as a soft start too??
All right, but apart from the sanitation, medicine, education, wine, public order, irrigation, roads, the fresh water system and public health, what have the Romans ever done for us? Life of Brian |
#9 |
Use a CRC. One cap after the diode, then the R, then another cap. A pi filter.
#10 |
I thought a pi filter was a CLC??
Whoops, I thought this was a question on reducing voltage rails to an amp...just saw the regulator reference on the first posting...
| Dropping rectifier filament voltage | Nightpuma | Tubes / Valves | 13 | 2nd February 2009 10:55 AM |
| dropping heater voltage | jarthel | Tubes / Valves | 17 | 21st September 2006 04:50 AM |
| Why is my MOSFET dropping so much voltage? | arnoldc | Power Supplies | 19 | 21st April 2006 07:52 AM |
| Using a dropping resistor in Zen V4 unregulated supply. | G | Pass Labs | 3 | 30th October 2002 04:17 PM |
