Hello,
What happens with inrush current in case of SHORT blackout for one cycle (20 or 16.6ms - 50/60Hz), few cycles, one second or more? How big is the current compared to power-on inrush current? For example: 600VA/230V toroidal transformer. |
#2 |
I found some info at noinrush.com. It seems that conventional soft start circuits and NTC are useless in case of voltage dips
. I will try to redesign my softstart.
#3 |
I tried to address this problem with a circuit that has a timing capacitor that can discharge much faster than it charges. But the chart shows how dire the situation appears to be.
#4 |
a delayed on and instant off for the bypass relay is OK for a few seconds of no power. For a few hundred mS of loss you would need a fast acting instant off and a fast acting relay to get the resistor and/or NTC back into circuit in time. For a one cycle loss, one would need a missing pulse detector and a very fast bypass, probably not a relay, maybe a FET bypass. But, I had not realised the significance of a missing part cycle. Would some kind of phase comparator be able to release in time for the re-establishing of power?
regards Andrew T. |
#5 |
kl, Is this a hypothetical question or do you have a problem with poor mains. I used a 600va toroid for years, but found I needed at least a 6.3 AT fuse. Even then it "parted" once on switch on.
It is possible as Andrew say's to have a missing pulse detector, but is it worth it all ? Providing the secondaries are suitably protected any risks are minimal with a large primary fuse, indeed the toroid manufacturer possibly has info on recommended input protection. Relays are OK but the contacts need to be suitably rated to prevent arcing. What seems a simple problem can either be " a non problem " or if you are determined to do something about it can become a fairly major design exercise. |
#6 |
Thanks for replies!
I have good mains, but ... just trying to design best soft start. I will continue to build my current triac-based soft start project. |
#7 |
A PTC thermistor and relay to short it out gives the ideal result. Burst control using triacs can generate RF noise and "irregularities" at the zero crossing. It's a no win situation really. The thermistor and relay offer no delay in the event of a mains drop out, but does that matter, the caps in the amp wil be charged so the toroid isn't seeing a low impedance.
#8 |
it's not the smoothing cap load that is the problem.
That is solved differently. It's the loss of flux in the transformer on power failure that we are trying to solve. A relay cannot drop out instantly. The best are of the order of 2mS and big relays that can handle input currents are very possibly >10mS to drop out. This drop out time gets much worse the more effectively we snub (with a diode) the back EMF of the coil. If the problem is as bad as that posted graph shows, then a relay can never solve that quarter cycle current surge. A whole cycle loss of power may even be too short to detect and for the relay to open in the 20mS available to detect and drop out.
regards Andrew T. |
#9 |
No easy answer is there ? To be honest I think it's a non problem really. I mentioned the reservoir caps because from fully discharged it must increase the primary current over many cycles I would imagine. If the secondary circuit wiring is low impedance it may well " overload " the transformer briefly, although I have never done any measurements.
Relays will never work for drop outs of a cycle or two. Anyone any data from the toroid manufacturers on what they recommend ? |
#10 |
But is that short time loss really a problem?
If it were to happen then transformers and motors *everywhere* will saturate flattening the mains waveform and your fuses should survive. |
| Toroid inrush current testing | zdr | Chip Amps | 33 | 15th March 2008 03:55 AM |
| MOSFET Inrush and Short Circuit Limiter | jackinnj | Solid State | 21 | 23rd June 2005 01:09 AM |
| inrush current | Jules | Tubes / Valves | 8 | 26th December 2003 05:38 AM |
| About Inrush Current | JDeV | Parts | 0 | 2nd December 2002 06:40 AM |
| Page generated in 0.10628 seconds (87.97% PHP - 12.03% MySQL) with 11 queries |
