Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th November 2008, 09:23 PM   #1
Default 9v Highly regulated/clean PS for guitar fx
Hello everyone, this is my first post on this forum. Looks to be a great forum that I can add to my list!
For almost a year now I have been working on a multi guitar FX pedalboard similar to those built by Pete Cornish for David Gilmour of Pink Floyd.
The board is comprised of a wooden enclosure housing around a dozen FX units. All but 3 are powered by 9vDC, most of which only pull about 5-20ma.
Two of them are AC powered tube units, requiring 24vct'd ac and 12vac both at 200ma. The third is about 50ma at 15vac with an onboard regulator.
I have a custom built tranformer arriving which has about 14 secondaries. (AC120 primaries). Except for those 3 FX units that require AC input, each secondary is rated at 12v 100ma (two are 200ma)
I want to build a VERY VERY clean noise free highly regulated power supply for each individual secondary and therefore each FX board gets its own independent power to reduce ground loops etc.
I am new to power supply design, but understand the basics. I want to to be VERY clean but I do not want to use something as complex as the Super Regulated supply i found on this board earlier. I saw in pictures that Pete Cornish uses extremely large (at least 10,000uf) filter caps directly after the bridge rectifier so I plan on doing this if possible with my transformer specs.
My questions are: with the 7809, and the 12vac power supply at 100ma (remember only about 20ma needed) How large can/should I go with the Filter cap and then what other features should I include to make it a very good power supply? I will post pictures of my board and an idea for a schematic I have so far.
Thank you! Sorry for the lengthy post!!
Old 13th November 2008, 10:39 PM   #2
the inside is sprayed with EMF shielding paint... a lot of progress has been made since these pics but you get the general idea...
Old 21st November 2008, 05:00 AM   #3
If u need clean power supply, then 7809 will not do.
At least u have to go for LM337 and the likes.
It is easy to get clean power from batteries. The 9V alkalines are good, but if u don't want the hassle of replacing them, then install NiMHs and a charger. Also wire a ON/OFF switch for the charger.
Gajanan Phadte
Old 21st November 2008, 08:50 AM   #4
Correction
Not LM337 but LM317
Old 21st November 2008, 09:11 PM   #5
star882 is offline star882  United States
star882's Avatar
http://www.maxim-ic.com/appnotes.cfm/an_pk/883
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
highly affordable LS cable killer tip Salas Multi-Way 11 8th May 2006 03:15 AM
conrad heatsinks - HIGHLY RECOMMENDED. tbla Swap Meet 13 15th December 2003 12:43 PM
highly unusual problem pundip Chip Amps 11 26th October 2003 10:11 AM
FS: RS 1147 full range - highly modified bbaker6212 Swap Meet 0 3rd October 2002 06:02 PM
FS: RS 1147 full range - highly modified bbaker6212 Swap Meet 0 3rd October 2002 05:59 PM
Page generated in 0.08968 seconds (73.77% PHP - 26.23% MySQL) with 10 queries
