Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th November 2008, 11:50 AM   #1
gearheadgene's Avatar
Default transformer winding
After running through the math, I find I require the following number of turns:
Primary: 11.48 Turns
Secondary #1 : 1 Turn
Secondary #2 : 4.5 Turns
Secondary #3 : 4.5 Turns
This is planned for a torroid (kool u) in a DCM flyback. Those 4.5 turns maybe should be rounded down, and maybe that primary 11.48 as well. Is running 1 turn a problem?
Any body care to chime in a good method to wind it? There's not much to wind, so it's got to be pretty easy
gene
Old 14th November 2008, 06:14 AM   #2
dtproff is offline dtproff  United States
FYI
The only way to get a half turn in a toroid is to drill a hole in the middleof the cor and pass the wire through.
Round up (not down) and let te duty cycle adjust the output votlage accordingly (it will pull in just slightly). Hope that helped.
Tony
Old 14th November 2008, 06:53 AM   #3
poobah is offline poobah  United States
poobah's Avatar
Work with your tolerances... Input Voltage Minimum can be tweaked to yield a integer primary winding...
Likewise for the secondaries... you have no option regarding the ratios of the secondaries... but the total number of turns can ne altered with core choice or frequnecy. Secondaries with turn counts this low will cross-regulate very poorly unless you wind them mutifilar (strands in parallel) for each seperate secondary.
Old 14th November 2008, 02:52 PM   #4
megajocke's Avatar
Originally posted by dtproff
FYI
If you were to do that it will have similar problems as trying to do half turns on an E-core without the extra loop in parallell around the other outer leg.
DIY Transformer Winding GlidingDutchman Parts 14 13th February 2012 06:00 AM
Transformer Winding microsim444 Power Supplies 4 3rd February 2009 09:58 PM
Winding a Transformer punchpeanut Solid State 8 1st December 2003 02:48 PM
Winding 1:100 Transformer for ESL ??? kristijan-k Everything Else 0 26th March 2002 11:08 AM
Winding 1:100 Transformer for ESL ??? kristijan-k Planars & Exotics 0 26th March 2002 11:04 AM
Page generated in 0.07682 seconds (72.12% PHP - 27.88% MySQL) with 10 queries
