Hello, i am a newbie
i try to use tl431(lm431) to make a dual power(pos and neg dc) supply for OP that can replace 78xx 79xx lm317 and lm137 series due to i think tl431 have better temputure performance than them,and tl431 is cheap sorry for my english, too bad and too many wrong spell but i believe that you can understand ![]() i don't know how to use tl431 for negtive power , i was confused, infact i design one, but use spice simulate, it can not keep the voltage, with the changes of RL(the load resitense) ,the voltage is change,so that can not fit my needs then i found fairchild 78xx manual have a tracking voltage regulator schemitic that useing a OP and a PNP to just tracking and follow the Positive voltage, so i use the typical TL431 plus a NPN postive regulator diagram and mix with the tracking way make this one please see the pic i upload |
#2 |
Sorry Charlie...
This really won't work. You need some type of switching element to generate the negative rail The simplest form is a switched capacitor inverter (Charge pump). These are good for small power applications only (~20mA range) For larger currents you will need an inductor and a DC/DC converter. Take a look at somem of the TI parts. One off the top of my head is the TPSTPS54353. But their are a lot of chinese and Taiwan versions available also. http://focus.ti.com/lit/ds/symlink/tps54353.pdf Sorry... I hope that helps. Tony |
#3 |
thanks
and due to i am newbie and not familiar the forum, i duplex post this at here: http://www.diyaudio.com/forums/showt...97#post1658197 the pic is at here http://www.diyaudio.com/forums/attac...amp=1226557423 and change the Q2 to PNP and swap the Pin 2 and Pin 3 (inverting and non-inverting input of OP LM741) then it works ok! |
| Please check my work :) | athos56 | Tubes / Valves | 11 | 17th August 2008 07:05 AM |
| please check my work | gary h | Tubes / Valves | 10 | 10th August 2008 10:52 PM |
| Pentode CCS: Would somebody check my work? | nullspace | Tubes / Valves | 5 | 13th March 2007 05:26 PM |
| TL431 for TDA1541 does not work | Bernhard | Digital Source | 7 | 26th January 2004 09:56 PM |
| ELF (Check my work, please) | fortyquid | Subwoofers | 4 | 1st October 2003 07:48 PM |
| Page generated in 0.08305 seconds (67.03% PHP - 32.97% MySQL) with 10 queries |
