Go Back   Home > Forums > Amplifiers > Power Supplies
Old 4th November 2008, 10:53 AM   #1
swin1 is offline swin1  Australia
swin1's Avatar
Default Transformer wiring question, series, parallel and center tapped
Hi there, long time reader, infrequent poster.
OK probably an awkward and silly question, but I am trying to learn more about options for wiring a transformer.
Now, I am comfortable with wiring transformers in series/parallel and know the general rules.
But, I am curious, I have a transformer with 2 different outputs - 16v-0-16v, and 38v-0-38v. Obviously it's useful for a high power integrated amp, but is there a way of providing 22v-0-22v by series wiring and out of phase (subtracting voltages,) or does the fact it's centre-tapped prevent any alternative wiring options.
Your input would be greatly appreciated, and perhaps could lead to a discussion that would help everyone have a better understanding of transformer wiring in general.
Cheers
Old 5th November 2008, 12:20 PM   #2
winny is offline winny  Sweden
Unless I have missed something, no.
You can get 2*22 V, but not 22-0-22.
Old 5th November 2008, 12:44 PM   #3
swin1's Avatar
Thanks, could you explain more about wiring multiple centre-tapped transformers together, in series or parallel, so that if I were to use more than one transformer in a system I might understand my step down options. I would really appreciate it.
I'll provide a picture of what I'm trying to get at if needed.
Old 5th November 2008, 12:57 PM   #4
Something like this.
Remember that this is not a good solution as the transformer utilization will be low. Can you rewind the 38 V transformer, or add windings to the 16 V one?
Old 5th November 2008, 11:33 PM   #5
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
It won't work that way, there is no way to join the voltages obtained.
I use to feel like the small child in The Emperor's New Clothes tale
Old 6th November 2008, 01:37 PM   #6
Eva,
Exactly! That's why I wrote 2*22 V but no 22-0-22.
Old 6th November 2008, 01:42 PM   #7
open up the outer insulation and separate the windings at the centre tap to create a 0-16-38+0-16-38Vac transformer. But while you can see the windings check/measure the wire diameters. They may be different in the two parts of the winding.
regards Andrew T.
Old 6th November 2008, 02:01 PM   #8
AndrewT,
Yes indeed!
Old 6th November 2008, 02:28 PM   #9
swin1's Avatar
hmmm... centre of transformer is filled with polyurethane with a nut in the middle for mounting, essentially blocking the inner core so I can't exactly unwrap the plastic, or if I could it would take forever to wrap up again. the secondaries are exactly opposite each other on the transformer, so I'm assuming it would take some unwinding to bring them together. I think this time I will leave this one alone and use it for something else or sell it.
So based on this discussion I'm assuming in general if centre-tapped transformers are to be used in multiples, in series, winding them back to find the ground reference and splitting that will give V-0 V-0 (whatever V is)?
Thanks a lot for your inputs!
Old 6th November 2008, 03:24 PM   #10
Originally posted by swin1
centre of transformer is filled with polyurethane ............................ the secondaries are exactly opposite each other on the transformer, so I'm assuming it would take some unwinding to bring them together.
drill a ring of small holes through the core filling. It will probably push out or take a little more effort.
Where is the centre tap lead? That's the one you need to access.
regards Andrew T.
Parallel/Series crossover wiring question cerupcat Full Range 7 21st November 2011 05:25 AM
Wiring Filaments with Center Tapped Secondaries JBasham Tubes / Valves 22 20th March 2009 08:24 PM
Center tapped transformer help Buzzy Parts 2 8th August 2008 09:35 AM
Wiring Toroid 14V non center tapped for PSU civilmonkey Chip Amps 7 23rd September 2006 08:12 PM
Parallel/Series Wiring Question Javachip Multi-Way 3 19th September 2006 04:25 AM
Page generated in 0.10154 seconds (79.51% PHP - 20.49% MySQL) with 11 queries
