#11 |
Swin1, Because the xformer has 3 wires, you can get ONLY two 16 volt outputs (which may be tied into parallel to provide up to double the possible current or a SINGLE 32 volt out put. You CAN NOT get any 22 volt output !! Also know that the output voltage are *very* approximate. You need to know whether the stated voltages are peak voltages or power-average voltages (RMS).
#12 |
ignore post 11.
you cannot parallel a centre tapped to obtain double the current. You can get a 22Vac output, but it is limited to the current available from the 38Vac tapping. But, it is not isolated from any other output voltage, this restricts what you are able to do with the other tappings.
regards Andrew T. |
#13 |
How do we know the 16-0-16V winding is not a low current one?
Doing what AndrewT suggest, unwrapping the plastic and separating the centertap is best. You can also check wire diameters then to calculate how much current you can draw from the different windings. A milliohmmeter is another possibility. |
| Parallel/Series crossover wiring question | cerupcat | Full Range | 7 | 21st November 2011 05:25 AM |
| Wiring Filaments with Center Tapped Secondaries | JBasham | Tubes / Valves | 22 | 20th March 2009 08:24 PM |
| Center tapped transformer help | Buzzy | Parts | 2 | 8th August 2008 09:35 AM |
| Wiring Toroid 14V non center tapped for PSU | civilmonkey | Chip Amps | 7 | 23rd September 2006 08:12 PM |
| Parallel/Series Wiring Question | Javachip | Multi-Way | 3 | 19th September 2006 04:25 AM |
| Page generated in 0.08016 seconds (74.44% PHP - 25.56% MySQL) with 11 queries |
