Go Back   Home > Forums > Amplifiers > Power Supplies
Old 30th October 2008, 03:27 PM   #1
hemos is offline hemos  Canada
Default Wiring series and then parallel with switch
Hi guys,
Just decided to use 5x 6V SLA batteries in a portable setup I am building. I'm using the batteries at 30V but I would like to charge them at 6V using my SLA charger. I can't find any SLA charger made for 30V battery packs.
I'm wondering if any of you would be kind enough just to draw me the schematic I would need to build in order to be able to switch from series to parallel on these batteries.
Thanks,
Max
Old 30th October 2008, 03:45 PM   #2
theAnonymous1's Avatar
Jerome Industries makes 15-cell (30V) lead acid chargers.
http://www.jeromeindustries.com/SLA-Switchmode.Htm
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 31st October 2008, 02:38 PM   #3
Tried emailing them and got no luck... I'll try to give them a call and see if they would sell me only 1 unit.
Old 2nd November 2008, 01:05 AM   #4
star882 is offline star882  United States
star882's Avatar
What about build your own charger? It isn't that difficult for lead acid. All you need is a current limited supply switchable between two voltage limits. Just start by charging to 2.4v per cell under current limit, hold the voltage for a preset time when reached, and then fall back to 2.3v per cell.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 17th November 2008, 01:34 AM   #5
If anyone have some spare time, I would be interested to purchase a custom made SLA charger for my 30V battery pack.
Max
Parallel/Series crossover wiring question cerupcat Full Range 7 21st November 2011 05:25 AM
Wiring Transformers Using The Series Parallel Scheme OMNIFEX Power Supplies 2 18th May 2009 02:55 AM
Parallel/Series Wiring Question Javachip Multi-Way 3 19th September 2006 04:25 AM
!2ax7 heater wiring? Series / parallel? glaznost45 Tubes / Valves 1 27th February 2006 11:51 AM
dB Gain with Series vs. Parallel Wiring 69stingray Multi-Way 16 21st November 2005 01:45 AM
Page generated in 0.07603 seconds (73.71% PHP - 26.29% MySQL) with 10 queries
