Go Back   Home > Forums > Amplifiers > Power Supplies
Old 22nd October 2008, 02:26 PM   #1
Default Recommended brands for tube HT psu caps
Anyone got preferences for really good quality brands of PSU caps for tube gear , with voltage ratings in the 250v - 450v range?
It's easy to find recommendations for cap brands when you're talking low voltage audio caps, but not so easy with higher voltages.
Any help here very much appreciated!
Old 23rd October 2008, 06:20 PM   #2
N-Channel's Avatar
Send a message via AIM to N-Channel
Studiochap-
I really like the Panasonic TS-series metal can large electrolytic caps. Working voltage ranges are from 16V to 450V. I recommend the TSHB series: 105 degrees C, high-ripple current, miniature size, and 3000hr life.
For a half-bridge, I would use no lower than 250WV, as two of these stacked across 220-240VAC (~325VDC), yield enough headroom to add active PFC'ing to the HB later on, if desired.
If you're doing a full-bridge, any of the 450VDC units will work fine, depending the desired power level. Hope this helps.
Steve
Old 23rd October 2008, 06:38 PM   #3
frugal-phile(tm)
planet10's Avatar
We use Solen's entry level poly caps. Big & expensive compared to elcos, but make a huge difference. Available in 250, 400 and 630V
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd October 2008, 07:25 PM   #4
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Big film capacitors should be used with great care. Inductance is proportional to terminal spacing at approx 1nH per mm. This rule holds for electrolytics too, which in the end are not that inductive with a typical 10mm terminal spacing on large cans. Electrolytics are more resistive too (ESR), at first this may be seen as a disadvantage but in some applications it's actually a headache preventer because ESR damps resonances. Modern electrolytics have nothing to do with the 40 year old ones found on tube gear.
I use to feel like the small child in The Emperor's New Clothes tale
Old 23rd October 2008, 07:55 PM   #5
Hi Steve and Dave,
your replies are very much appreciated!
Gwyn
Old 23rd October 2008, 08:54 PM   #6
Hi Eva,
Thank you! Interesting - and your comment on ESR and resonances made me wonder therefore , about the effect of ESR on the sonics of caps in the audio chain.
I would very much appreciate your comments on the thread I also have " Upgrade 250v caps for tube mic".
As far as caps go I've replaced literally thousands of them ( recapping audio mixing consoles... ) over the years, without taking the time to learn enough about them.
Gwyn
Old 24th October 2008, 12:03 AM   #7
00940 is offline 00940  Belgium
The rifa PEH169 have been discontinued but still can be found on the web (let's say ebay...). I've not made extensive comparaisons but in the HV supply of a tube headphones amp, they were coming quite close to a full MKP caps bank (cheap solen). Obviously, dismiss my comment if you make more than a pair of amps.
They were available up to 450vdc iirc. I've got a pair of 3300uF/350Vdc for which I'm still trying to find an use.
for example (and example only, this is not a recommandation for the seller): http://cgi.ebay.co.uk/EVOX-RIFA-PEH1...742.m153.l1262
Btw, I finally settled for this amp on a bank of old industrial mkp caps (11 x 20uf iirc, surplus on ebay) that were a bit better than the solen in that position. And they had terminal which were close to each other.
Ben.
Old 20th August 2009, 02:37 PM   #8
cowboy99's Avatar
Default Rifa PEH169's are still in production!
The famous Rifa PEH169's are still being made, although since Kemet bought out Rifa and BHC the 169's are being made in the UK now. Their not readily available (especially not/never in the US) and usually have to be ordered via min qty. of 80-100 or so with a serious long lead time of 4-5 months min. Way out of most of our realm!
But, not to fret: AudioCapUK regularily stocks several PEH169 varities. Contact Matthew, he's great to do business with and pricing includes shipping! He is the only source I've found the higher end SS PSU caps.
http://www.audiocap.co.uk/peh169-low...itors-54-c.asp
But for the 'tubee' higher voltage ones you might check out Svalander Audio (I've never bought from them), but I'd suggest you see if Matthew might have or can get what you want first.
http://www.svalanderaudio.com/shoppen/lytareng.php
PS: I recently (June '09) bought (8) of the PEH169's 22,000uF 63V 105deg stud mounting 'TOP of the Line' 'BIG BOYS' from AudioCaps and was super pleased to see that the production date was barely 1 month old!!!!!
Last edited by cowboy99; 20th August 2009 at 03:12 PM. Reason: added link to make post more 'ON TOPIC' and grammar
Old 20th August 2009, 06:42 PM   #9
piero7 is offline piero7  Italy
piero7's Avatar
ICAR polipropilene here: click here they costs few euro
Mounted in my Aikido, simply great and not expensive
Big can caps brands? HaLo6 Everything Else 6 25th March 2009 08:09 AM
current tube manufacturers and or brands opcom Tubes / Valves 8 10th June 2008 08:32 PM
all you wanted to know about brands of caps -and were afraid to ask- federico moreno Parts 4 30th March 2006 08:48 PM
Tube brands.. who is best/most popular.. GeirW Tubes / Valves 3 7th February 2004 04:17 PM
Recommended Tube Books for DIY Eric Tubes / Valves 12 6th February 2002 07:54 PM
Page generated in 0.12447 seconds (79.31% PHP - 20.69% MySQL) with 11 queries
