Go Back   Home > Forums > Amplifiers > Power Supplies
Old 15th October 2008, 02:56 PM   #1
gain is offline gain  United States
gain's Avatar
Default can anyone explain this regulation issue?
got 14.76V on the top rail and -15.21V on the bottom. stays rock steady at those values with increasing loads too. the opamp i'm driving it with doesn't seem to mind, just was curious why it was occurring.
schematic attached.
thanks
Old 15th October 2008, 03:20 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
There is a production variation in most components.
Within a bunch of same transistors produced the current gain can go from 100-700!
1% resistors nominal 1000 Ohm ( 1 k ) can range 990 - 1010 Ohm.
5 % resistors can be anything from 950 - 1050 Ohm.
Same for chips like regulators.
The variation from nominal 15.00 for you is 14.76V and -15.21V.
Which actually is very small: -1.6% and +1.4%
And as you have discovered the opamp does not mind a bit
http://www.national.com/ds/LM/LM7512C.pdf (positive regulators)
http://www.national.com/ds/LM/LM7905.pdf (negative regulators)
National LM7815 datasheet gives these tolerance facts:
Min 14.25V and Max 15.75. This is +-5% accuracy.
Most exemplars however will be closer to 15.00, than this 5% variation.
lineup
Old 15th October 2008, 04:14 PM   #3
gain's Avatar
thanks lineup!
makes perfect sense.
Using 0D3's for DC regulation in Aikido cbutterworth Tubes / Valves 29 21st February 2008 04:26 AM
shunt regulation?? AudioGeek Tubes / Valves 4 25th July 2004 11:04 PM
Zen Regulation hacknet Pass Labs 3 5th April 2004 08:21 AM
Transformer regulation dhaen Parts 5 3rd February 2004 09:16 PM
LC regulation??? Michel Solid State 4 30th October 2001 05:42 AM
Page generated in 0.07926 seconds (71.57% PHP - 28.43% MySQL) with 11 queries
