Hi I’m new to the TL 494 IC and my preference is for research and my interest in high power DIY CAR audio amplification as well as commercial CAR power supply design like the rockfordfostgate brands they so commonly found in 90% CAR amplifier SMPS I thought I will ditch the SG 2535 IC for now
![]() Questions & Misunderstandings ![]() There are 2 error amplifiers, are they used for PWM control ?or a cut off when a voltage exceeds a predefined voltage, like a comparator? And error amp2 usage would be a current sensor or even a temperature sensor? Is PWM control only allowed on the DTC Pin 4 of the chip are there other ways of doing it? If so how? Are most CAR SMPS driven with a 1:1 PWM 50%ON 50%OFF duty cycle or do there duty cycle vary according to the load? Is it a must that the TL 494 require totem pole gate drivers in a push pull configuration to be present ? I have witnessed some CAR audio amplifiers never use this technique, or are it dependent on the gate drive, output voltage, and stability that it is introduced? Thanks guys I will add more as I investigate and conduct research. Thank you in advance and thank you all for keeping this forum alive!
There’s nothing worse than the smell of burned output transistors!! |
#2 |
Both error amplifiers, as well as the DTC pin, have the ability to clamp the duty cycle. The one imposing the lower duty cycle limit dominates. These error amplifiers may be employed to limit output voltage (regulation) and current.
Almost all amplifiers work with a fixed duty cycle resulting in an unregulated output. The outputs of the TL494 can either source or sink current depending on the way they are connected, but they can't do both things at the same time. Since totem pole drive is always required for MOSFET gates, an external transistor, diode and resistor combination is usually employed (on each output) to pull down the gate as soon as the TL494 stops pulling it up.
I use to feel like the small child in The Emperor's New Clothes tale
#3 |
Thanks for the quicky reply
Can i get some examples on this please ?
#4 |
Like this
http://focus.tij.co.jp/jp/lit/an/slva001d/slva001d.pdf This IC was used a lot in TV/VCR equipment in the 1980's. |
#5 |
Thank you
Mooly, Strange i was under the impression that the error amp was used to completely shut down the chip, not adj the pwm, the example show single ended config, is the example true for push pull configurations ?
#6 |
Hi Reactance,
Sorry I am no expert on SMPS design. I have worked on lot, mainly high voltage types and so on fault finding etc but thats a different thing. |
#7 |
#8 |
I’m still unable to adjust the PWM of the TL 494 using one of its error amplifiers
Only the DTC PIN 4 allows me to adjust the pwm if i adjust the voltage from 0V to 3.3V I get 3% to about 50% control in a push pull layout, the reason why im not using the DTC Pin 4 is my soft start circuit is configured to control the PWM at start up and sensing logic sits there and future sensing will control shut down on PIN4 example temp sensor logic. I don’t have a picture at hand but here is my layout of the two error amplifiers, PIN 15 = VRef (+5V) PIN 16 = GND PIN 1 = 0 v~ 2.5v adjust PIN 2 = ½ Vref 2.5 v When varying from 2.5 to 0 or 2.5 to 0v on PIN 1 the PWM Just shuts down and back up when approximately 1v or so, but never adjusts the PWM
#9 | |
Eva Im not 100% with you can u please elaborate ?
#10 |
Anyone ?
| Some basic questions about Q | wigginjs | Multi-Way | 8 | 20th October 2004 07:22 PM |
| Basic LED Questions | lgreen | Parts | 22 | 19th December 2003 06:26 PM |
| Basic Questions | DarkMage | Multi-Way | 2 | 5th November 2003 02:51 PM |
| Some basic questions... | Ziller | Everything Else | 5 | 13th January 2002 02:49 PM |
| Basic Questions | wnichol | Solid State | 4 | 16th November 2001 04:59 AM |
| Page generated in 0.10708 seconds (79.94% PHP - 20.06% MySQL) with 10 queries |
