Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th October 2008, 10:32 PM   #1
vena2a is offline vena2a  Czech Republic
Default primary winding for push-pull converter @100amps, 100kHz
Hello,
I am new in here, but I want to show you something. It is a 100 amps primary winding for push-pull converter which should work at 100 kHz.
This winding is placed on ETD49 core and is designed of 0.5 mm thin copper plate. I decided for this solution because depth of penetration is roughly 0.2 mm (at 100 kHz) and I wanted to reach small resistance of winding.
As you can see on the picture, the winding consists of two similar parts (each part makes two turns with center). These two parts are connected in parallel into one winding.
So, what do you think bout this design.
Old 8th October 2008, 12:50 AM   #2
jamesrnz's Avatar
interesting, do you split the bobbin?
do the phase a phase b winding go in opposite directions?
are you insulating the foil completely?
Old 8th October 2008, 07:24 AM   #3
areza is offline areza  Bangladesh
winding a transformer is challenging task , using foil to wind is more challenging, this one really looks like most challenging,
bobbin seems not ok with foils, need some mods,
those connecting foils coming out from winding need to be replace with round wire, so they can be bent proper direction with out breaking ,
Old 8th October 2008, 07:43 PM   #4
to jamesrnz:
No I won't split the bobbin. This winding can be made of E-shaped 0.5mm copper foil (the foil will be turned on the bobbin).
Of course, the winding will be insulated, except the ends and center of winiding. The ends and center of winding will be soldered on PCB ... sometring like SMD.
The phases windings (which are in fact connected in parallel into one bigger winding) are the same. The windings have the same directions ... they are little bit (about 40 degrees) turned each other. You can see that on the picture. The first turn has red pin on both of windings ... so the directicrion is the same.
Old 8th October 2008, 10:08 PM   #5
If the skin depth is .2mm, a .5mm winding is thicker than necessary (or effective). Winding a thiner tape should be easier. The width of the tape needs to be sufficient to keep the current density (and I^2 R losses) low enough to prevent excessive heating of the winding.
Old 9th October 2008, 01:33 AM   #6
jamesrnz's Avatar
does not the skin depth penetrate on both sides of the tape 0.2 x2=0.4 so 0.5 wouldn't be far off?
Old 9th October 2008, 03:19 AM   #7
The relatioship between skin depth and Rac/Rdc is addressed in this paper. While the current wants to flow on both surfaces of the winding, proximity effects complicate this.
http://focus.ti.com/lit/ml/slup197/slup197.pdf
Old 9th October 2008, 12:41 PM   #8
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Have you considered one or more small toroids, say 28mm in diameter, with as much strands of 0.5mm magnet wire as required? This seems much easier to manufacture since only conventional parts and methods are used. No wonder it's the preferred approach in car audio amplifiers. E and ETD cores are seldom used for 12V push-pull applications.
I use to feel like the small child in The Emperor's New Clothes tale
Old 9th October 2008, 01:10 PM   #9
homemodder's Avatar
Hi Eva
I understand you know a thing or two about switchmode supplies. Could you possibly direct me to what you would call a excellent diy design here on these threads for a car supply. Ive built plenty on the design as on rod elliots pages, not exactly the same but as per schematics given in elektor 1994 issue. Im looking at high efficiency and higher power. Also would one get more effenciency from a torroid than from a etd type former?? I used litz wire on my etd formers but some time back I read somewhere on the net that its better to use a larger diameter wire because of the skin effect, this confused me as its contradicting what is said in the elector article.
Old 10th October 2008, 07:23 AM   #10
Tahmid is offline Tahmid  Bangladesh
Tahmid's Avatar
Hi Eva,
Just a query: Why are E and ETD cores seldom used for 12v push-pull applications?
If you please explain, it will be helpful to me.
Thanks.
The tallest building in the world starts from the first brick.
পৃথিবীর সর্বোচ্চ দালানও প্রথম ইট বসানো থেকেই তৈরি হয়েছে।
Page generated in 0.10261 seconds (79.39% PHP - 20.61% MySQL) with 11 queries
